Question about Kenmore Stove / Oven / Range Bake Element 9758519
I have a Kenmore model no. 911.4658816 stove,oven. Oven temp. does not match with setting I enter. the oven bake element is new and gets hot but temp seems to back off or never gets up to setting I enter or even goes past where I set it. bake items are not cooked inside. I this possible a thermostat problem and if so where is it located?? this unit has the digital selection for temp. and push buttons for bake, broil ect. Is themostat behind front control panel?? thanks for any help you may provide.
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
markevans
  • 148 Answers
SOURCE: kenmore dishwasher model 665 motherboard
relay or sensor
Posted on Dec 21, 2007
reg501
  • 413 Answers
SOURCE: Kenmore model 16039/665.16039403 will not start...does not appear to have power
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Posted on Jun 02, 2008
SOURCE: Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Posted on Feb 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Top element doesn't get red hot on bake but does on broil is my controler bad
The top element (broil element) will come on when you put it in bake only to help the oven temp get to the desired setting. If your temperature is reaching the right degrees you shouldn't have a problem.
Nov 02, 2010 | Kenmore Ovens
Oven will not pre heat
Simple to test a bake element or range top burner element.
First, visually see if the element has molten gobs on the tubular-looking element, and/or is cracked. It will be obvious.
And if you do not see anything obvious, you should still test the element with a voltmeter. Many elements are set up so you can unscrew a screw where the element gets attached at the inside rear of the oven, and then pull the element into the stove a couple inches, enough to unhook the wires and then be able to put a voltmeter tester on each end of the element (set to the OHMS setting) to see if the element has continuity.
IF the element is good, then...
...You can also then make sure the wires are not contacting metal(BE SURE OF THIS),... and then plug the stove back in and test the wires to see if you have 220 volts. If not see, which of the two wires has 110. Then if you know which one does not have the 110, then you UNPLUG THE STOVE again and then access the rear of the stove and trace that dead wire from the element plug-in back in the range. You will physically be able to trace that wire.
When working with 220 elements in anything...please realize that usually one leg wire of the 220 volts (in other words, 110 volts) is always 'hot' even though the switch to it is off!! Always remember that!
Jun 22, 2010 | Kenmore Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Stove / Oven / Range Bake Element 9758519 Logo
44 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
