Question about Ovens
F7 10 flashing on frigidaire range - Ovens
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Lock light is flashing when I push bake it says door
Hello meathead4094 - Often when the LOCK light is flashing, it is because there is door malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear the flashing. If issue persists, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
Apr 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire flashing F1
Hello wills_amber - Typically, error code F1 indicates that the range has detected a runaway temperature issue (overheating). Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) on the range will need replacing.
Mar 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire range ffef3016lbe flashing f-11
You have a shorted out keypad - (F11, 12, & 13) disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC
Aug 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Display shows PF-time of day flashing on Frigidaire range.None of the buttons respond. Rene
Try unplugging it to reset the main control board witch most of the time its your clock.then push enter.if don't don't work then your clock (main control is bad .or if it has a touch pad it could be bad.call repair clinic .com at 1-866-822-0890 or 1-800-269-2609 and order parts there.they can tell u how much
Nov 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The oven blew a circuit and now keeps flashing F1. What can I do to fix it?
That means the control board on the range needs replaced. Simply find the model number on your oven and click on this link for Frigidaire Appliance Parts and I could give you a price and help over the phone to fix it.
Dec 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F9 Flashing on Frigidaire 30" range
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Dec 31, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire cplef398ccb Flashing F7
I would replace the EDC
Feb 01, 2009 | Ovens
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
