Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a Kenmore model 911.4658816 and the oven does keep a accurate temp. if set to 200 degrees for example it may only go to 180 or so. baking does not workout as items are always uncooked in the middle. Is this a thermostat problem or?? if so, where is it located. The heating element gets red hot and is pretty new. old one had broken, burned spot. Thanks for any help on this.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
@00 or 180, does not spoil cooking. If that is your only problem, then set oven to 220 or 230 with your thermostat in the oven. Then compare the reading in the oven to the one on the control panel.
You can then set the stat on the control panel to higher or lower, to compensate for the difference.
A new stat might not make that much difference as other issues might be involved.
Posted on Oct 20, 2013
  • 58 Answers
SOURCE: Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Posted on Mar 12, 2008
  • 26 Answers
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
  • 1073 Answers
SOURCE: Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Posted on Apr 21, 2008
TheMobilian
  • 8220 Answers
SOURCE: Oven not heating
Your ignitor is weak. Change it.It should be very bright ,if it is dim it is weak.
Posted on Jan 19, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
My baking is set on celcius instead of farenheit.
sorry i dont know how to switch it for you but i do know how to convert c to f
Degrees c times 1.8 plus 32 equals f temp
Example 100c is boiling point so 100 times 1.8 equals 180 add 32 to that equals 212
zero degrees c is freezing point
zero times 1.8 is 0 plus 32 is 32
200 times 1.8 is 360 plus 32 is 392 ect ect ect
Jul 22, 2011 | Whirlpool Kitchen Ranges
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven stays at 150 degrees at all times...even
clean pilot assembly. then oven thermostat
Jan 01, 2010 | GE JGBS20 Gas Kitchen Range
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Kenmore Oven (model 3627361190) underheats when baking.
Double check the sensor. It should ohm at 1150. Look for a frayed wire on the sensor.
Oct 12, 2009 | Kenmore Ovens
I have a kenmore self cleaning gas range. For some reason, when I turn on the oven (ie bake), a lot of heat is coming out from the ''exhaust'' between the range and the panel. And the oven inside is not...
this is normal allowable temps are upto 180 degrees
i know it sucks but it is normal for that model
that is as long as your oven reaches and maintains temp
Sep 29, 2009 | Kenmore Kitchen Ranges
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
