Element tv code direct tv
Cant get tv audio to go to rca surround sound unless I use ear phone jack blue ray vcr tuner all work fine only 2 days old never worked element 40"
    Scholar:
  • 112 Answers
Not following... This is what I think you may be saying: You can't get the TV to use the RCA input?
The reason for my confusion is "rca surround sound". RCA will only carry left and right channel (stereo). It can't push surround sound unless it's setup as a direct input [typically an 8 channel input, where you would have 8 RCA cables (or 4 pair) connected].
The headphone jack, if using a 4-pin headphone jack (it has 4 sections of metal, vs a 3-pin, which only has 3 sections of metal), may be able to send something closer to surround sound, but it wouldn't be a true surround sound. You would need to use fiber optic, HDMI, DVI, or digital coax cable.
The sound settings in the OS on the computer need to be set to push the surround sound, or it will only push stereo. You'll probably need to spend some time there testing all the setting options.
Posted on Oct 22, 2013
4 Suggested Answers
  • 126 Answers
SOURCE: sound but no picture
Hello Dabizot,
With the price of the new tv's, I would recommend getting a new tv. It's only a 19" and you can get a flat panel 19" for less than $ 200.00 It may cost you $ 100 plus to get it repaired along with any new parts. If you want to spend less money try looking at the yard sales, people are always selling used TV's for cheap.
Posted on Nov 16, 2008
  • 77 Answers
SOURCE: When I install ATI x600 drivers i get message
hiya wasif_2000
this is driver bug in the catalyst drivers take a look at amd's site and try and download the lastest drivers for your gpu, u could also update directx from microsoft........should sort this out for you
hope u can get it working.......
Posted on Feb 23, 2009
bertus_kriel
  • 121 Answers
SOURCE: audio does not work on tuner
m ake sure the jacks at the back is set correctly, from the tuner car auido out to the line in on the motherboard sound then make sur the aux cable is inside the case also fro the card to the motherboard mail me if any other questions, bertus_kriel@yahoo.com
Posted on Oct 08, 2009
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
If you need further help, reach me via phone at https://www.6ya.com/expert/lucas_1df14fee4a945e4f
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
How to set up my rca blue ray to my 50
You should find a Phono output on the back of the TV. Some even have a Digital Optical output as well. Depending what inputs your surround system has you should be able to hook it up to one or the other.
Aug 02, 2012 | RCA Audio Players & Recorders
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
How do i put the surrround sound on my tv?
Depends on the complexity of your home theater system, but if you are just wanting to get sound from your tv to a generic souround sound, this is very simple. On the back of your tv, there is a audio output with 2 rca connectors. One is white and one is red. Also on the back of the sound system is the same colored inputs. Get the needed cable to connect the 2. You should have surround sound. Given you tv doesnt have audio outputs, your media player ( dvd, vcr, blue ray, sattelite) should have an audio output. Connect the electronic the same way as stated above.
Sep 10, 2009 | Durabrand 5.1 Surround Sound Computer...
I have a new 52" Samsung HD TV with a new Sony Blue Ray player and a Shaw PVR cable box all connected with HDMI cabes. I also have a older digital RCA model RTDVD1 sound system with no HDMI connection and...
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Jan 24, 2009 | RCA RTDVD1 System
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Jan 08, 2009 | GoVideo Go Video DVD/VCR Combo
Sound
Three (3) possible ways:
1. use the audio out of the TV (if available) which would normally be red/white RCA and connect to any of the free INputs of your DVD surround sound system;
2. remove the cable INput of your TV and feed it to a tuner such as those in a VCR or any other device (some DVDs have TV tuners also). The VCR's Video OUTput would go to your TV while the Audio OUTput would go to any of the free INputs of your DVD surround sound system;
3. if your cable uses a box/decoder and has the yellow, red & white RCA, its a matter of splitting the red/white signal to feed both your TV and DVD surround sound system or simply remove them from the TV and feed them to the DVD surround sound system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Televison & Video
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
