Question about Honda Eb5000 Eb7000 5000 7000 Generator Service Repair Manual 61z1200
I have a Honda EB7000I generator. I just put a new Honda factory inverter in it. It will start up and run smooth for 7-10 seconds then will stall. Over load light comes on when it stalls. Will start right back up for 7-10 sec and stall again. Since it sat for some time with a bad interter I took carb off cleaned the bowl, jet, needle and seat, cleaned plug and checked for water in the gas. All is good but still stalls. I unplugged inverter and same thing happens, turned eco throttle off same thing.
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Posted on Oct 09, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
SOURCE: Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Posted on Apr 25, 2010
2016burke
  • 43 Answers
SOURCE: generator dies when load is applied
I beleive,, edder: short, wire off alternater. or bad alternater
Posted on May 09, 2012
SOURCE: honda eu 3000 won't run, cleane bowl,cleaned filter. fresh oil new plug got spark, will run for 10 seconds, the will not crank again. wait 20 min. it like crank an run 10 seconds?
i usually do a quick test of a small few onzes of fuel down the plug hole and reinstal plag and see if i9 fire up and run for a lil bit. maybe 5 -10 seconds. now i know i have spark . most usually our wonderful fuel is the problem. its just nasty now. it can stick a needle to the seat. it can hold her open . one way ya flood out. the other ya starv out. give it a try.
Posted on Nov 02, 2012
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Oct 15, 2016 | Honda EU2000i Companion Inverter Generator...
My Honda EU3000 inverter has spark, turns over but wont run. I have taken the plug out, added fuel to the cylinder, it runs for a second then stalls. Looks like its not getting fuel.Something plugged?
if it has a metal tap under the tank, they have a habit of corroding internally and blocking the fuel flow
test by removing the hose to the tap and turning it on
if it is a slow trickle or drips ( anything but a full flow ) consider s new tap
check for corrosion at the needle and seat area of the float control
Sep 17, 2016 | Honda EU3000iS Inverter Generator
Honda eb 7000 inverter generator won't stay running. It runs for 12 seconds and stops. I tried disconnecting the oil sensor but no luck.
it appears to be insufficient fuel flow to the carby
check for blockages in the tap , lines , tank filter, needle and seat area
Aug 03, 2016 | Honda Electrical Supplies
I have a Honda EB 7000I generator. It runs for 7-10 seconds then stalls. When it stalls the red LED overload light comes on. I just put a brand new Inverter in it. Since it sat awhile with a bad...
As silly as this sounds, Harbor freight toold generators by "Predator" will shut down if the generator is not on level ground, and the oil level is not at the desired level, crazy but there is an inbuilt oil level sensor. maybe this might be the answer. hope iy helps, good luck.
Oct 19, 2013 | Motorcycles
Generator dies when load is applied
May 09, 2012 | Honda Eb5000 Eb7000 5000 7000 Generator...
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Mar 20, 2011 | Yamaha 2500 Watt Industrial Inverter...
EU3000is running rough and idle hunting.
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
Sep 07, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
May 28, 2009 | Electrical Supplies
Honda Eb5000 Eb7000 5000 7000 Generator Service Repair Manual 61z1200 Logo
160 people viewed this question
Top Honda Electronics - Others Experts
Bill Boyd
Richard Warren
Richard Warren
Geoff White
Geoff White
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
