What symbol is for hot air - Heating & Cooling
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Depending on the unit, it is generally symbolized by a small flame
Posted on Oct 22, 2013
How do I set my Timer on the Hot Water Tank to give me hot water all the time. The slider has a clock symbol on one side and a beam symbol on the other?
Timer is not identified.
Usually the slide switch is override button.
Clock symbol probably represents timed functions.
Other symbol probably represents 'always ON'
Move switch to both positions and see what happens.
Add a comment with clear description of timer for more information:
http://waterheatertimer.org/How-to-set-timers.html
Jun 21, 2011 | General Electric Water Heaters
AC has freon but it quits and starts blowing hot air then it has a blue thermostat symbol on dash has 2 codes po 128 and po 118
Both codes are for the coolant temp, the blue symbol means the car is cold, check the fans to make sure there operating and check coolant level
Jun 21, 2011 | Volkswagen Beetle Cars & Trucks
DONT KNOW WHAT SIMBLES ON REMOTE CONTROL ARE EG HOT COLD ETC
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
Dont seem to get cold air, what is the best symbol to use? There is sun, snowflake, rain drop and few others either way it takes forever to get the house cold and sometimes it just simply just does not...
To get cold air set temp 23 degree and mode "cool".
Now symbols:
4. Sun- Heat
Dec 30, 2010 | Heating & Cooling
AC not working in 2007 Passat. Was told the compressor is good ad plenty of refrigerant but blows only hot air. One day it was good the next day it was not. Shawn Phipps
I had the same problem with my 2007 passat. The external ait temperature sensor measures the outside air temp and displays this on your dashboard computer. If this sensor is not working properly it can cause your ac to blow hot air. If there is a little snowflake symbol by the air temp on your display that is an indication that this sensor may be bad. Get this sensor replaced and it should fix your problem.
Apr 06, 2010 | 2007 Volkswagen Passat Sedan
How do I get a split system to blow hot air, i need instructions on using the remote and knowing what the symbols mean. PLEASE.
Usually, you just press the mode button until a picture of a sun appears on the screen and then raise the temperature setpoint
Jun 06, 2009 | Heating & Cooling
Sony camcorder
condensation is the situation where a sensor detects presence of moisture inside that is hazardous to the gadget, this will not be removed if no air flow can get inside, best way is to open any side and blow hot air inside. Not hot that can damage some parts.
Feb 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
My Dimplex DAC12AC aircooler is blowing out hot air
Hi,its possible have a problem your PCB Board ,the 17c is so cool setting but blows hot , and the E3 simble its min High Cooling , pls check ur PCB board to the nearest service center.
Jan 07, 2008 | Heating & Cooling
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
