Question about Coleman Heating & Cooling
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new Sequencer 10kw, 12kw Sequencer Relay,and a new MARS 90340 SWITCHING RELAY COIL 24 VAL 50/60 HZ 9100Y233Q00. The coils click on and heat and then click off without the fan coming on. The repairman is not sure why the the sequence is off and everything doesn't work together. Can you help, please. Thank you, Carol Davis
  • 499 Answers
I have a 1987 mobile home with a coleman electric - 5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpg
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Posted on Oct 19, 2013
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
Ican anyone help me find a wiring diagram for a coleman DGAT075ADC FURNACE?
Did you look on the inside of the removable cover? That would be the normal place for this information.
Apr 13, 2013 | Coleman Mobile Modular Home Gas Furnace...
Wires to big to fit in new coleman furnace breaker
Go to Home Depot, get a wire splitter for each wire coming in (probably 2). Then run #10 to the 30 amp breakers or #4 wire to the 60 amp breakers. Harder to explain than to do. Basically, what they do is act like a "Y" branch for wires; the existing #2 wire goes under 1 screw lug, the new #10 & #4 go together under the other lug. Another solution that I do often is reuse the bus bar from the old furnace on the new furnace, properly wrapped in 10- 20 mil tape! Hope this helps! Last note: use NoLox on ALL the connections, as electric furnace lugs get hot and tend to losten over time, causing arking that destroys the lugs. Also, I'd bet your old wires are aluminum and your new wires are copper- another reeason for No-Lox!!!
Feb 22, 2013 | Coleman Mobile Modular Home Electric...
The pilit went out and cant seem to get it lite
Heading says electric furnace, obviously not correct. Can you please get back with proper make and model of furnace? Thanks
Jan 13, 2013 | Coleman Mobile Modular Home Electric...
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Need to rewire my 1987 jeep wrangler
I have a book with the whole electrical, haynes repair manual has the diagrams . 1987 thru 2003.I have 1987 wrangler with some issues. How would I get you infobook 50030
l
Dec 18, 2008 | 1987 Jeep Wrangler
Heating & Cooling Logo
546 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
