I have an air condition unit model AVNH246BLAC and want to know if it blows hot air as well as cold air and if yes, how do you access this via remote control
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit. If it is a remote control just set the remote to heat mode.
sounds like the air-conditioning expansion valve is probably not working correctly here is a way you can fix your air conditioning:
Realize that auto AC is basically a refrigerator in a weird layout. It's designed to move heat from one place (the inside of your car) to some other place (the outdoors). While a complete discussion of every specific model and component is well outside the scope of this article, this should give you a start on figuring out what the problem might be and either fixing it yourself or talking intelligently to someone you can pay to fix it.
Become familiar with the major components to auto air conditioning:
the compressor, which compresses and circulates the refrigerant in the system
the refrigerant, (on modern cars, usually a substance called R-134a older cars have r-12 freon which is becoming increasingly more expensive and hard to find, and also requires a license to handle) which carries the heat
the condenser, which changes the phase of the refrigerant and expels heat removed from the car
the expansion valve (or orifice tube in some vehicles), which is somewhat of a nozzle and functions to similtaneously drop the pressure of the refrigerant liquid, meter its flow, and atomize it
the evaporator, which transfers heat to the refrigerant from the air blown across it, cooling your car
the receiver/dryer, which functions as a filter for the refrigerant/oil, removing moisture and other contaminants
Understand the air conditioning process: The compressor puts the refrigerant under pressure and sends it to the condensing coils. In your car, these coils are generally in front of the radiator. Compressing a gas makes it quite hot. In the condenser, this added heat and the heat the refrigerant picked up in the evaporator is expelled to the air flowing across it from outside the car. When the refrigerant is cooled to its saturation temperature, it will change phase from a gas back into a liquid (this gives off a bundle of heat known as the "latent heat of vaporization"). The liquid then passes through the expansion valve to the evaporator, the coils inside of your car, where it loses pressure that was added to it in the compressor. This causes some of the liquid to change to a low-pressure gas as it cools the remaining liquid. This two-phase mixture enters the evaporator, and the liquid portion of the refrigerant absorbs the heat from the air across the coil and evaporates. Your car's blower circulates air across the cold evaporator and into the interior. The refrigerant goes back through the cycle again and again.
Check to see if all the R-134a leaks out (meaning there's nothing in the loop to carry away heat). Leaks are easy to spot but not easy to fix without pulling things apart. Most auto-supply stores carry a fluorescent dye that can be added to the system to check for leaks, and it will have instructions for use on the can. If there's a bad enough leak, the system will have no pressure in it at all. Find one of the valve-stem-looking things and CAREFULLY (eye protection recommended) poke a pen in there to try to valve off pressure, and if there IS none, that's the problem.
Make sure the compressor is turning. Start the car, turn on the AC and look under the hood. The AC compressor is generally a pumplike thing off to one side with large rubber and steel hoses going to it. It will not have a filler cap on it, but will often have one or two things that look like the valve stems on a bike tire. The pulley on the front of the compressor exists as an outer pulley and an inner hub which turns when an electric clutch is engaged. If the AC is on and the blower is on, but the center of the pulley is not turning, then the compressor's clutch is not engaging. This could be a bad fuse, a wiring problem, a broken AC switch in your dash, or the system could be low on refrigerant (most systems have a low-pressure safety cutout that will disable the compressor if there isn't enough refrigerant in the system).
Look for other things that can go wrong: bad switches, bad fuses, broken wires, broken fan belt (preventing the pump from turning), or seal failure inside the compressor.
Feel for any cooling at all. If the system cools, but not much, it could just be low pressure, and you can top up the refrigerant. Most auto-supply stores will have a kit to refill a system, and it will come with instructions. Do not overfill! Adding more than the recommended amount of refrigerant will NOT improve performance but actually will decrease performance. In fact, the more expensive automated equipment found at nicer shops actually monitors cooling performance real-time as it adds refrigerant, and when the performance begins to decrease it removes refrigerant until the performance peaks again.
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
You do not mention the model. Most aircon remotes have a mode button which has three or four icons. On cooling there will be a ice crystal icon on the lcd display. Pressing the mode button (sometimes behind a cover on the remote) this icon will change. You want to set it to the "sun" shaped icon
