Question about AO Smith SQ1152 Pool Pump Motor
Pump shuts of when meeting slight pressure or load conditions.
    Sergeant:
  • 216 Answers
This could be caused my several issues. A Amp meter used on the cord to see if the FLA ( Full load Amperes) are being draw and causing the Thermal overload to shut off the pump.
The other issue could be that the windings are bad, you could have bad brushes, or possibly the run capacitor has failed.
And the last thing is that the pressure sensor switch might also be faulty. it may have some debris in it and when you get pressure it\'s enough to tell the pump it has pressure and shifts off the switch.
Posted on Oct 20, 2013
Error code F09 for whirlpool
F09 Overflow condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2e96NFcLn
Sep 06, 2013 | Washing Machines
I have an f27 error on my washing machine. Can you explain to me where the pressure switch is? I have the front, back, and top off of the machine.
Error code f27 is OVERFLOW CONDITION.----------
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.----------
Check:----------
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
----------- This should help.Thank you.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F09 in a AU AWO 5761
F09 Error = Overflow Condition
Potential Causes
• Check/ Clean Drain Pump Filter of foreign objects
Dec 29, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
Model number 11042822200
You're washing machine is probably a WHIRLPOOL. F09 is as follows
"F/09" Overflow Condition
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
F09 code on front load washer. What is this?
F09 error means Overflow Condition.If the Overflow contact on the pressure switch is Closed for more than 60 seconds,Overflow condition will occur.In an Overflow condition,the Door will remain locked and the Drain Pump will run constantly,even if Pause/Cancel is pressed twice and the Display is cleared.
1. Check the drain hose and make sure it is not plugged or inked.
2. Check Wire Harness connectors to the Drain Pump,Pressure Switch and Central Control Unit(CCU).
3. Check/Clean Drain Pump Filter of foreign objects.
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off.
6. Check the Pressure switch for proper operation.
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F09 Error
This is what F09 means
Condition
Overflow Condition
Check and repair
Dec 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wet cloths need help please!!!!!!!
F9=Overflow Condition
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE 3T front load washer
Hope this helps ...... F09 is a Overflow Condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check/ Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation PLEASE rate my solution
Oct 04, 2007 | Kenmore 44832 Front Load Washer
Kenmore HE3 F 09 error message.
F09 Overload condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check / Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation Replace failed component.
Sep 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
AO Smith SQ1152 Pool Pump Motor Logo
59 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
