Wish to connect laptop, HP Pavilion dv6000, to Toshiba Television Receiver model 32SL410U. What connector is needed?
    Problem Solver:
  • 12 Answers
Use a VGA to DVI converter. If there is a DVI converter then use DVI cable:)
Posted on Oct 30, 2013
My laptop is an HP Pavilion dv6000. I cannot connect to the net and viewing my device drive shows that I problems with some driver including my network controller, Ethernet controller and modem device on...
Even though the laptop says DV6000, they always have a more specific model number on the bottom sticker.
The best way to do this is grab a flash drive and go to another computer. Open the internet and go to hp.com then click on support and drivers. Type in your model number, then operating system and download the drivers needed to your flash drive. Then bring the flash to the pavilion and load drivers from there.
Mar 01, 2011 | Computers & Internet
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Nternet connection
Hi:
You need to go to :
www.hp.com
click on the drivers and support link,
type in the model of your laptop, and then download all the drivers they list.
Burn them to a disk, or copy to a thumb drive.
Transfer them to your HP, and open and install them, and you should be good to go!
Nov 23, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have a HP dv6000 laptop that needs a motherboard replaced. can you tell me how to do that?
hp has step by step directions on there website for full rebuild of the dv6000.. let me get you the link here now...
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Sep 30, 2009 | HP Pavilion dv6000z Notebook
Is it difficult to replace a motherboard to HP Pavilion dv6000?
To rate it from 1-10. It's a 6.
You got to watch out for the ribbon cables connectors.
Two person will make it easier. The one with good eye sight and small hand should undo the ribbon connectors.
HP DV6000 has many problem with bad video chip problem.
The only way to fix it cheap is to swap the board.
Jul 09, 2009 | HP Pavilion dv6000 Motherboard
HP Palilion dv6000 can't connect to a TV
The first thing you need to do is after you connect the cables.. hold down the fn key and press f4. this should bring the screen on the tv. make sure your tv is in the AV mode. if not try with a vga cable.
However if it still does not show up then probably the display drivers are corrupted. reinstall the drivers from the recovery manager > advance options > hardware driver installation.
Hope this helps....
Regards,
Anup
Apr 07, 2009 | HP Pavilion dv6000z PC Notebook
I need the instruction manuel book for a hp pavilion dv6000 special edition please
There are a number of different dv6000 models. Here is a link to the support page at HP for the series:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=dv6000&submit.x=0&submit.y=0
Pick your particular model and you should be able to download the manual and any other information you need.
Feb 20, 2009 | Compaq Pavilion ZT3280US Notebook
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
