Question about Haier HEATER CPN10XH9 Air Conditioner
When I switch my haier portable air condtioner/heater to heat cold air comes out the back. I took the exhaust out of the window for the fall/winter season so the cold air is exiting into the room. Have I missed something????
  • 400 Answers
In heat mode it is acting as a heat pump. You must have the exhaust connected to the outside air.
Posted on Oct 21, 2013
SOURCE: 9000btu Haier portable air conditioner
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Posted on Jul 18, 2008
  • 24 Answers
SOURCE: Room temperature reads 95-99 degrees F, not cooling the room
one hose is the heated condensing air and one hose is the intake air. if this unit is not working correctly and u just purchased it take it back. if the landlord will replace it tell them. do not call a service tech to check this unit out if u know 4 sure the temp is set right and it continues to blow hot and the exhaust hose blows outside and the unit is set to cool you are money ahead to replace it. hopefully a landlord or recent purchase can bail you, you can find these units at home depot lowes and get them 4 about 400 dollars. hopefully it's covered somehow by warranty or landlord but the cost for checkout and service will exceed the cost for replacement. have you tried to unplug the unit leave it unplugged and try again. have u cleaned the filter. have you noticed ice anywhere. maybe a light that tells you the drain is plugged i don't wan't to get you're hopes down when you are burning up but check these things and let me know if u see any abnormalities. do you leave the unit running in hopes that you will come home and it works? check for ice is there air blowing constantly? if u dont get air flow you could have a fan thats out or its iced up. let me know.
Posted on May 28, 2009
  • 24 Answers
SOURCE: exhaust hose
i could not find that model number on the haier website www.haieramerica.com you can get the manuals and parts list there. you dont need the haier hose however lowes and home depot sell what im guessing is three or four inch hose that you can use say a dryer vent flex hose or alumaflex hose to connect this unit. unless you are going for the looks.
Posted on May 31, 2009
SOURCE: Haier 12,000 portable unit. Red light comes on STOP appears
Drained tank then operated fine
Posted on Oct 08, 2009
  • 10865 Answers
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Hotpoint MAC155 won't pump out any air
It needs to be cleaned , coils a,knd vents and filters are dirtyx. You can actually tajik it out and spray it out with garden hose and let dry completly and should work fine.
Sep 22, 2012 | Washing Machines
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
Hi I've just purchased a used HPRD12XC5 portable air conditioner. It did not come with Air Intake/Outlet hoses, exhaust adapter or window slider kit. Is there somewhere I can buy these? Thanks -...
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Hope this helped you. Please let me know. Thanks.
Jun 02, 2011 | Haier HPRD12XC5 Portable Air Conditioner
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Edgestar Portable AC/Heater
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Dec 02, 2007 | Heating & Cooling
Haier HEATER CPN10XH9 Air Conditioner Logo
96 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
