Question about Microsoft Xbox 360 Console
2 red lights
After 5 mins my xbox 360 turns off giving 2 red lights on left. I have checked the back of unit and it seems that the right fan is not working. How can this fan be turned on as it's malfunction is causing overheating.
  • jawad Oct 01, 2007
    My xbox360 has been repaired by a technician who charged me US$100. My fan is working ok the console has been tested by me for many hours of playing the reason he gave me is that 1 of the cpu attached to the fan went down and was replaced , to which I am not satisfied. I told him that there must be a disconnected cable of the fan but he said that there was no disconnection and the fan supply comes from the cpu.
  • 23 Answers
If your box never has been open you could send to MS for repair but since it is not the 3red rings error. They will charge you I think. You'll have to call and tell them your problem. If you want to fix the problem yourself you are going to have to open the box. Once you have it open you got to check the fan. Look and see if any wires came lose,disconnected or burnt up. If they seem ok check the clip attached to the motherboard. Just follow the wires on the fans. Pull the clip out push it back in. This is to make sure clip is in tight. You dont have to put the 360 back together to test the fans. Plug the power in and the video cable and boot it up. If it works great if not your going to have to buy replacement fans.
Posted on Sep 27, 2007
  • McloveN Oct 16, 2007
      The fan is NOT connected to the CPU it is connected to the motherboard! The CPU and the GPU are the 2 Chips on your motherboard that have the heat sinks attached to them. They run the 360 Graphics and Processes. Don't deal with that guy anymore he is bad news brother.
After playing a game for 5 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console is still on and the controller is still doing what it was...
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Jan 20, 2010 | Microsoft Xbox 360 Console
Hey i have 2 red lights on my xbox 360 on the left side can u help
The unit is over heating , if the fan quickly goes
to full speed you have an air gap in the C.P.U. heat sink
The fix is to re-seat the heat sink to the chip . This is done
by applying even pressure on the heat-sink and turning it on
to see if you have good contact. and repeat till the fan speed
drops .
If you have any questions just comment and ill respond.
Oct 19, 2009 | Microsoft Xbox 360 Console
How do you fix xbox 360 e 74 any assistants would be a lot of help
There are two ways to fix this error.
First Take it to a shop that is able to re-flow the G.P.U.
with out damaging the P.C. board. And then securely
clamp the heat sink down . Im not sure if Microsoft does this.
Second Take the unit apart , remove the G.P.U.s Xclamp
replace with nylon washers and 4 8-32-3/8 long screws
lightly and evenly torque all 4 screws. Place half the
fan over the large heat sink and turn the unit on.
affter 5 min the fan should be at full speed and in
anouther 3-5 min you should get two reds . Unplug
and reassemble . The unit should be working.
Oct 18, 2009 | Microsoft Xbox 360 Console
2 red lights on the left hand side. comes back on for 5-30 minutes then goes off red again.
Your xbox 360 console is overheating. Make sure all your vents are clean and unobstructed. Allow to cool for a few hours. If problem persistes you'll need to contact microsoft. May be an issue with the cooling fan
Oct 05, 2009 | Microsoft Xbox 360 Console
Ring of death. i suggest you send your 360 to microsoft for repairs
Aug 14, 2009 | Microsoft Xbox 360 Console
Two red lights on xbox 360
hey Cmull
i had this problem before because my xbox 360 was old, but this fix is only if ur out of warranty because it involves you openning up your xbox 360. It also isnt the case if your xbox 360 isnt very old, it probably means ur fans are finished. Well, back to the solution you take apart your xbox 360, just do a google search on how to dissasemble your xbox 360 if you already dont know how to do so. Just take off all the covers until you see this
then just get and air compressor or something to blow all of the dust out. i did it for mine and it never happened ever again. Enjoy.
Jun 21, 2009 | Microsoft Xbox 360 Console
Don't use a intercooler they will bugger your Xbox 360 for sure. From what you said you have your console where it can get plenty of air, this is important as the RROD is caused by overheating. As for your problem, try unplugging the unit and removing the HDD, put the HDD back on and plug it all back in again. If this fails, since the unit is only 5 months old call Microsoft, their phone numbers are on the web site, they will pay for the product to be returned, and when you get it back it will be as good as new.
Jun 06, 2009 | Microsoft Xbox 360 Elite Console
What does 2 flashing lights mean on an xbox 360?
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan.
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Dec 31, 2008 | Microsoft Xbox 360 Console
Oct 28, 2008 | Microsoft Xbox 360 Elite Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20,615 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
