Question about Ford Vehicle Parts & Accessories
1994 tauras/no heat - Ford Vehicle Parts & Accessories
    Scholar:
  • 147 Answers
Check the water level in the radiator when the engine is cold. Fill to the top and make sure the surge tank is at the proper level. If that's all good the problem comes down to a plugged heater core or the dash heat control.
Posted on Oct 20, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
97 ford tauras not blowing heat
Sounds like one of your blend doors is not closing. There should be only 1 blend door motors on your car.lookat the dash and try to close it by hand,if there is a difference then you will need a blend door motor
Oct 27, 2012 | 1998 Ford Taurus
98 tauras over heating
check for thermostat, faulty water pump,or blogged radiator.
Sep 26, 2012 | 1998 Ford Taurus
My blower dosn't work to curculate the air and heat in my car and tranny slps but i have fluid on the dipsick
You will need a complete transmission
rebuild, if you have any slipping
Slipping starts long before you notice it
Tauras & Sable transaxle life is well less
than 100,000 miles
Mar 26, 2011 | 1998 Mercury Sable
How do I know if my tauras has ABS brakes?
left front tire squealing noise.
Sep 14, 2010 | 1994 Ford Taurus
Where to find Belt routing 94 Tauras 3.8
Should be on the back of the pack that the new belt comes in.
Mar 29, 2010 | 1994 Ford Taurus
1995 ford tauras ihave a new thermostat checked the blender and ihave good heat going threw the heater core but no heat in the car
it sound as if there is a blockage in the system give these websites a try www.alldatadiy.com and www.autozone.com also www.taurusclub.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
Nov 05, 2009 | 2001 Ford Windstar
The compressor on the Air Conditioning will not
First thing to check is the fuse. Next ---If the freon pressure is low the compressor clutch will chatter. If the freon is all gone or very low, the pressure switch in the system will not allow the clutch to get power, so will not turn on. Or it could be the switch in the dash board. If you pull the electrical connection at the clutch, then with separate wires and alligator clips run power direct from batter to clutch --the clutch will throw in if it is good. If so, you will know it is probably the pressure switch. If you have good pressure, then it could be the pressure switch itself has failed.
Jun 11, 2009 | 1994 Ford Taurus
Air nor heat works the blower doesn't come on
leak in the radiator? Check your coolant...
Apr 28, 2009 | 2001 Ford Taurus
Install Tach. in 1994 Ford Tauras
Just checked sun and rac tachs.(both common brands)..typed in brand name and install...both came up with good instructions and wiring diagrams but neither have the same colours as yours. Check anyhow or if different brand, type in name of your unit.
Apr 25, 2009 | 1994 Ford Taurus
Remove back seat
If I remember correctly, you can push down on the bottom half of the seat bench while pusing back towards the back of the car, it should release the latch system so you can pull the lower seat cushion out, the back rest portion of the seat may be bolted in.
Apr 06, 2009 | 1994 Ford Taurus
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
