Question about Coleman Powermate Powermate 5000W Generator
Have coleman 5000w starts an runs fine for about 5 minutes then dies will not start again unless let cool down for 10-15 minutes what can it be?
    New Friend:
Sounds more like an ignition coil.
Posted on Oct 23, 2015
    Master:
  • 342 Answers
Check the valve clearances that's a good place to start if it still has a spark once it has cut out
Posted on Nov 05, 2013
SOURCE: COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Posted on May 06, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Coleman Model PM0545007.01 6250 W
Seems that your carberator maybe clogged at the jets. However, before you purchase a rebuild kit for your carberator make sure the fuel flow coming out of the fuel tank has a steady flow. I have seen where the fuel hole or line at the tank becomes clogged. If you feel the the fuel flow is poor grab a wire type coat hanger and clean out the hole and fuel line. Also, check for fuel filters, replace it if you have one on the genset.
Posted on May 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Posted on Nov 05, 2009
Rebgagnon
  • 382 Answers
SOURCE: Husky 5000w Generator with a Subaru engin.
Fuel system needs cleaned. Dirt or build up get's in the passages and it can not properly regulate the fuel/air mixture. Being it runs well in choke position I would suspect it is plugged on the idle passage. Sometimes you can add a very small amount of "Seafoam" to the fuel and let it run while slowly moving the lever to the run position and this will clean it out. It is also possible that the fuel tank has a small amount of water in it. Good luck and have a great day.
Posted on Feb 15, 2010
SOURCE: Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Posted on May 18, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
My Coleman Powermate 5000 cranks fine and runs for 10 mins and seems to over heat and cuts off. Fresh gas, oil fine and carb cleaned very well. The muffler gets cherry red at night. Carb adjustment? ...
Carb is probably the problem as you thought. It sounds as it might be running too lean, meaning the mixture does not have enough gas in it. Try turning the high speed mixture screw (remembering the position that you started from) counterclockwise in 1/8 turn increments (adds more fuel to the mix) until it starts to run rough then turn back to mid point from where you started from. Have you tried checking for obstructions to the proper circulation of air through the fins for cooling. Make sure all the shrouds are installed. Some people think by removing any covering over the engine will help for cooling, it doesn't they are designed to have all the parts on it for proper cooling. Hope this helps a bit. Good luck.
Jan 11, 2011 | Coleman Powermate Powermate 5000W...
My coleman powermate 5000W generator is very hard to start. When I squirt gas in the carburator chamber it will start for a about a minute and then it dies. It acts like it is not getting any gas. I...
The carb. has a nut holding the bowl on.Remove this nut and you'll notice a hole in in it that goes from side to side.You'll also notice one through the center that connects to the other.Make sure these holes are clean.Use a small pin..etc.Chances are it will stay running when you assemble the carb again.
Oct 14, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Feb 27, 2009 | Coleman Powermate Subaru 5000W Portable...
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
166 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
