Question about Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer
Install gasket kit - Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer
Install crankshaft kit on 2004 hyundai sonata 6 cylinder 2.7l engine
Really need more information...It sounds like they didn't give you a complete gasket kit...You will have to remove and re-install other components just to be able to see the crank shaft....You need the front and rear oil seal for the crank..,Oil pan gasket..,exhaust will have to be removed also...etc.......NEED MORE INFO..
Jan 24, 2015 | Hyundai Motor 2004 Sonata
Are there instructions to install the carburator rebuild kit for a Mantis 2 cycle engine?
not really as you disassemble your carb lay it out the way it comes apart pay special attention to the gaskets and diaphragms to their position many times the gasket and diaphragms will stick together match new gaskets and diaphragm then reassemble they put several different gaskets in these kits so look carefully
Oct 13, 2012 | Garden
1991 pontiac sunbird le.draining ****** fluid.installing transmition filter kit.should i use gasket goo or somthing else when installing gasket.any tips
You might want to check with your local auto parts dealer, but yes, I have had success with gasket goo, in the past. Also, check the pan seal to make sure it's clean and not bent.
Aug 08, 2012 | Cars & Trucks
WOULD LIKE THE PART NUMBER FOR REBUILD KIT TO A 1999 F150 4.6L ENGINE. COMPLETE SET AND GASKET SET ONLY PLEASE.
the 'kit' that you are looking for varies from parts distributors. if you are going to the dealership for this then you will be getting a very long list of numbers that you really don't need any how. If you are replacing the gaskets for this vehicle then you want to go to the local parts store and ask for the "upper gasket kit" for (insert vehicle here) and then you will get what you are looking for. if you are looking to rebuild the bottom end, the block, then you want to get the "lower gasket kit" but a good upper gasket kit (ie. Felpro, Victor Reins, etc...) then you should get a head gasket, valve cover gasket, and intake and exhaust gaskets. the lower gasket kit can include but not always (you should ask what gaskets come in it) oil pan, freeze plugs, and front and rear main seals.
Apr 18, 2011 | Ford F-150 Cars & Trucks
I just installed a new top end kit and collent is leaking out the threads on the head bolts
Possibilities ::
Head bolts not torqued --
Warped head --
Defective head gasket --
Head gasket not installed properly --
If you want to further discuss, let me know. --
Charlie
Feb 01, 2011 | 2003 Yamaha YZ 125
HOW TO FIX A BLOWN HEAD GASKIT?
Buy a gasket kit for the upper end. Remove the valve cover intake and exhaust manifolds. Remove the head bolts. Remove head and clean up block from old gasket material. Take the head to a machinist and make sure that it is not warped. If it is warped either replace the head with a new one or have it machined true. Install new gasket and get torque specs with new head bolts and follow torque sequence using the correct torque specs. Clean exhaust, intake and valve cover of old gaskets. install new gaskets and torque according to specifications.
Nov 27, 2010 | 1993 Jeep Cherokee Country
I tried to start my troy vac/blower and it takes for ever to start and when i used the vacuum it runs slower and finally stalls and wont start backup
Your machine probably needs: 1. the carburetor adjusted 2. The carburetor cleaned 3. A gasket and diaghram kit installed in the carb
1. To adjust: http://www.zamacarb.com/tipspage.html
2. To clean: Remove, disassemble and clean. Here are the carb parts: (Only clean the metal parts)
http://tech.flygsw.org/walbro_tuneup.htm
3. Gasket and diaghragm Kit: You will need to know the carb model (probably a Zama)
Find the model of your repair kit here: http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
An RB kit is a complete rebuild kit (contains all the parts in the G & D kit)
A G & D kit is a gasket and diaghragm kit and will cure most of the carbs ills.
Many online vendors sell these and there are an abundance of them on Ebay.
Nov 12, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Gasket Kit 916/996/998
base gaskets and side cover gaskets. Does it also include necessary o-rings or do they need to be purchased separately?I just bought one of these kits for a 916 a few weeks back it includes; Head gaskets Base gaskets Inlet manifold gaskets Valve seals Numerous green O-rings - not sure what they're all for because I didn't use them. The gasket kit cost the same as 2 head gaskets seperately.,,
Nov 10, 2008 | 2002 Ducati 998 S Bayliss
Nov 10, 2008 | 2002 Ducati 998 R
Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
