I upgraded my thermostat to a digital one. when i removedd the old one only the red and white wires were used. i also replaced the thermostat wires. i hooked up all the wires according to color red to r, white to w, etc... there is no a/c unit, heat only. this is a coleman gas furnace model # DGAH077BBSB. the old thermostat also had fan on and auto fuction switch, but the fan would not ooperate continuously in the on position. the fan still will not operate in the on position does this model furnaace support continuous blower motor function?
  • 499 Answers
i upgraded my thermostat to a digital one. when i - 73dd0b2c-2c43-4bb0-bae3-3442bd37e755.pngdaa78e14-af8e-4fec-a854-c8b30f7c0ad8.jpg
As your unit had just 2 wires, Red and White, you had just heat only with no AC and no fan on as described as you have no green circuit wired up at the furnace or thermostat, you can add a relay if not equipped but that would make your unit very old.
Posted on Oct 19, 2013
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
machtcl1
  • 61 Answers
SOURCE: blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Posted on Jan 02, 2009
  • 2464 Answers
SOURCE: blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Posted on Feb 17, 2010
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
I am replacing a 10 year old Honeywell Thermostat with a mercury switch with a new programable digital Honeywell OS#RTH7500D1007 MD 0638. There a 4 wires coming out of the wall and are installed on the old...
You are on the right track, you can hook the same 4 wires to the new thermostat without the jumper you had on the old thermostat. The jumper wire that is on the new thermostat can stay with no problems. Just connect the wires to the same terminals on the new one and your good to go!
May 10, 2011 | Honeywell Electronic Programmable...
Hi! We have a really old williamson thermostat (not sure about the model but it says t87fi89i 2 8047 [dont know if it's i or 1 either]). We want to replace it with a honeywell t87n east-to-see thermostat....
On most applications for heating the red and white wires are used,however I would check what wires are connected to terminals on old thermostat. These connectons should be labled with initial of wire color,such as R,W,G,Y or Rc. If your green wire is hooked to R or whatever just hook new thermostat up like the old one and you should be ok. Hope this helps. Thanks.
Nov 12, 2010 | Honeywell Electronic Programmable...
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
Programmable thermostat
I am unsure of your question, but if you are just replacing your old thermostat with a new one, then connect the red wire to the Rh or R terminal and the white wire to the W terminal on the thermostat. Hope this helps
Jan 09, 2010 | Honeywell Electronic Programmable...
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Can't get new thermostat to work
When you have only 2 wires it is set up to run just a heater only. If this is a central heat/air unit, you would have 4, red for Hot, White for heat, green for fan, and yellow for cooling. sometimes they will have a blue wire that's not being used for a spare only.Some times you can use just the heat part of the stat if you connect the Red to r and if the subbas'e says Rc and Rh .If so, try connecting red to red and if it does say Rc and Rh that means red cooling and red heating.Run a jumper wire across the 2 reds along with the red from the wall. Connect white to w.Try programming the heat and see if it fires up. If not, you will have to replace stat with a 2 wire Heating only thermostat. Do not pull any wires up from the transformer as you will burn it out!! Just remember, 2 wires are for a heater only!4 are for heat and cool, and 8 are used for a heat pump.Sometimes the new stats have the red jumper wire in place and all you have to do is hook your red to either end of the jumper, and then white to W. If no RCand RH, get a heat only stat, or it will never work believe me, I know this.Good Luck and let me know if you need more help. Shastalaker7
Nov 07, 2009 | Heating & Cooling
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Jun 24, 2009 | Goodman CKL30AR30 Air Conditioner
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
