Question about Philips Televison & Video
How to scan for channels with remote control - Philips Televison & Video
    New Friend:
  • 8 Answers
Hit guid or menu
Posted on Oct 19, 2013
How do i channel scan on a phillips tv without remote control
change your remote control so that you can auto scan
Jun 30, 2015 | Televison & Video
Lost all programs need to retune How
  1. Scan the channels
    1. Press the Menu button on your remote control.
    2. Select Channel and press OK on your remote control. For Aerial you must choose the Cable option.
    3. Go to Auto tuning and press OK twice on your remote control.
      - Set the Automatic tuning screen to Cable (vertical) and Digital (horizontal). - Then press OK on your remote control.
    4. Enter the following values:- Search mode: Quick- Network: Manual- Network ID: the code for your region (22 for Flanders and 12 for Brussels)
    5. Press OK on your remote control.
    6. For Frequency enter the value 322000 and press OK on your remote control.
    7. For Modulation enter the value 256QAM and for Symbol rate enter the value 6875.
      Then select Search (or Next, this differs by type of TV) and press OK on your remote control.
    8. Your TV now scans the channels.
Jun 02, 2015 | Samsung Televison & Video
Perform channel scan
Connect a free to air external or indoor aerial to your tv you should find some local free to air channels
Oct 11, 2014 | Toshiba CT-852 Remote Control
Westinghouse service manual
I would expect that it means tuning to every possible over the air and cable channel it is designed to receive to see what, if anything, is available on each of those frequencies at that input.
It's probably the kind of thing it might do the first time you plug the set in, and can probably be repeated if you wish by finding a command in the menu somewhere that says something about channels and scanning.
It's not really something the remote control would do, it's something the unit controlled by the remote control would do.
What exactly is the problem you're trying to solve?
Jul 26, 2014 | Westinghouse RMT17 LD3240 EW32S3PW...
How to scan for TV channels
Channel searching is performed as part of the setup process. Your remote should have a way to direct the TV to display the setup steps
Jan 10, 2013 | JVC LP21036-023A Remote Control...
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
I want to go to channel 3 so i can go on cable , but the remote doesnt let me !
Hello; All TV's made in the last 20 years are computer controlled. The TV wants you to do a "scan ", so it can MEMORIZE all active channels. IF you are connecting your set to a cable BOX or OTHER, the set can only SEE the Channel 3 output from the boxes. No scan will work when doing this! In this case don't expect to be able to use the channel UP or Down keys on the set or remote, because the set does not know any channels due to no memory of a scan. You can, however key in the channel # and the set should go to that channel, unless the set is defective. John
Dec 19, 2010 | RCA Televison & Video
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Digital converter box only gets 2 channels
You may need a different antenna. See www.dtvanswers.com for more info.
Jul 23, 2009 | RCA Universal Remote Control
Televison & Video Logo
13 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
