Question about West Bend 82602 Poppery II Popcorn Maker
Instructions popper - West Bend 82602 Poppery II Popcorn Maker
Do you need to add anything to the popcorn machine
Depends on your machine. What bran/model dso you have? If it is an air popper, NO. Adding anything will damage the machine.
If your machine is not an air popper then you likely need to add some oil. I currently have a WestBend Stir Crazy Popcorn Popper. You use a tablespoon of oil for each 1/4 cup of popcorn in the bottom of the popper. See here; an instruction manual is available.
You are best to check with the manufacturer of your popccorn popper.
Jan 30, 2011 | Kitchen Appliances - Others
I have two of your popcorn makers and lost instructions on the amounts of ingrediients. I need to know how much corn, oil and salt to put in aluminum popper thank yhou
The manual says to put 1 to 3 tablespoons of oil in the popper, and when hot, add 1/2 cup popcorn. Salt it after dumping the popped corn into a bowl.
Nov 11, 2010 | Back to Basics Popcorn Popper (PC6)...
I've lost the instructions, how do i use it
this video should help http://www.expotv.com/Back-to-Basics-Disney-Popcorn-Popper/2f-fPq
Oct 31, 2010 | Back to Basics Disney Popper PD5 Popcorn...
I CANNOT FIND INSTRUCTIONS HOW MUCH OIL AND POPCORN DO I PUT IN AND WHERE? THANKS, ARLENE,///
I have the same popper and the instructions. You do not need any oil. There is a circle lid piece at the top of the popper. You put the pop corn seeds in that lid and then pour the seeds in through the hole at the top. The popper needs to be off while you do this. Once you've added the popcorn you can then turn on the switch located on the back of the popper. It looks like a small light switch. The popcorn will start popping and it may smell funny at first if you haven't used it or used it properly. You have to monitor it and turn it off yourself- using that same switch. And per the manual you need to wait 15 minutes before you use it again.
We use ours all the time and love it. Hope this helps.
Aug 21, 2010 | Nostalgia Electrics OFP501 Old-Fashioned...
I borrowed an air popcorm popper. I have no instructions. Help!
Remove plastic cover. place kernels up to the fill line point (generally about a cup) place cover back on and put bowl under shoot. Plug in and prepare for a great low cal snack
Apr 09, 2010 | Salton Kitchen Appliances - Others
Presto 04830 i need a manual for this microwave corn popper
Go on line to www.gopresto.com and look for ' instruction manuals' and 04830 Microwave Popper.
Print it.
Jan 07, 2010 | Presto 04820 PopLite Popcorn Maker
I have lost the directions for use of power pop popcorn popper with power cup concentrators
You are looking for instructions for the 04830 Microwave corn popper. They can be printed at the Presto web site www.gopresto.com look for instruction manuals on the home page.
Jan 07, 2010 | Presto 04821 Orville Redenbacher's Popcorn...
BOUGHT AN WEST BEND POPCORN POPPER FOR CHRISTMAS PRESENT DID NOT COME WITH INSTRUCTION, IT WAS THE LAST ONE AND A FLOOR MODEL#82306. NEED INSTRUCTIONS REALLY FAST. PLEEEAAASE!!!!
Go to website focuselectrics.com and click on West Bend icon
You can download an instruction manual under the replacement parts/popcorn poppers area.
Dec 24, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Where can I find an instruction manual for this popcorn popper?
Go to http://www.nostalgiaelectrics.com/ and click on their customer support link.  At the bottom of their customer support page there is a box to enter the model number of your popcorn popper to get a manual.
Apr 12, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Salton PCST22 Popcorn Popper Measurement
This is the typical measurements for salton poppers
for 3 quarts/litres of popcorn:
1 tbsp. (15 ml) of oil
1/3 cup (85 ml) of popcorn kernels
1 (15 ml)* of butter margerine
Mar 02, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
