Question about Cosco Baby Gear
How to make strap longer as child grows - Cosco Baby Gear
  • Cosco Master
  • 1,629 Answers
Hi Wanda
We would need to know the make and model of the product you are using to be able to advise.
Posted on Oct 27, 2013
2 Suggested Answers
Neoklassic1
  • 70 Answers
SOURCE: The straps are too tight on my child
Ok. First don't panic, I did the same thing with mine! lol. In the front of the seat where your childs legs hang, there is a velco flap. Lift it up and you'll see a metal button(but it doesn't look like a button). Push it in and at the same time pull one of the shoulder straps. This will loosen the strap. Then adjust accordingly. If you remove the back plastic piece you will see all the straps underneath if you want to eventually replace them. You can also adjust the height from the back if needed. Good Luck!
Posted on Oct 17, 2008
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
Nov 17, 2015 | Cosco Baby Gear
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
Do I have to use the safety straps on my kid's high chair? She's a really passive child and doesn't move around a lot but I find the straps are quite restrictive.
Speaking from experience, you should ALWAYS use the safety straps on all your kid's equipment. Even a child that likes to stay still, could suddenly decide to reach for something or get adventurous and take a tumble. My little one fell out the high chair and we spent all afternoon in the emergency (thankfully she was ok), but it's just not worth the risk.
Aug 29, 2012 | Chicco Baby Gear
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Oct 08, 2008 | Eddie Bauer 3-In-1 with Latch
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
Jan 22, 2008 | Cosco Summit 22260 - Bouncing Sheep
Britax evolva 123
you need to buy longer straps from britax www.britax.co.uk
Dec 28, 2007 | Baby Gear
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Baby Gear Logo
35 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
