Question about Kitchen Ranges
What does error code f1e2 mean and how to fix it
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Problem with the board. First try tightening up the harnesses on the board; make sure the buttons are not stuck, turn oven off and on again and see what the code reads..if any.
Do not have exact explanation for error code but know that that is where your problem lies.
Posted on Oct 20, 2013
3 Suggested Answers
  • 146 Answers
SOURCE: Whirlpool Gas Oven
The F1, E2 codes mean you have UL ac-dc errors. This means you need to replace the control.
Posted on Dec 21, 2007
vest6
  • 196 Answers
SOURCE: Error code F1E2
The code F1E2 refers to a watchdog circuit in the ERC (Electronic Control Card). This can only be corrected by replacement.
Posted on Dec 30, 2007
Whirlpool stove 465 error code F1E2
unplug the unit for 2 minutes. if the problem persists replace the clock.
Jun 04, 2017 | Whirlpool Kitchen Ranges
Duet model WfW 9351yw00 code f1e2
Can not find your model, but here is the same error someone else had and what they found out along with posts from other users.
http://themysterioustraveler.blogspot.com/2004/11/f1e2-means-were-erc-ed.html
Nov 27, 2015 | Washing Machines
Duet model WF w 93515 w 00 code F1e2
An F1E2 error code is a motor control unit error. The main control has detected that the motor controller is not doing something right. Sound funny, I agree but this is what the manufacture tells me. I assume the washer has been working fine and then this pops up? The checks for this is to find the motor controller at the bottom of unit and locate the wiring to it. Unplug washer and then unplug each wiring harness and plug back in. Test. If problem still exists, then locate the main control at top and do the same. Unplug wires, and test again. If still issue, the its a 50/50 guess, between motor controller and main board. I don't like this code because I can only go so far then I have to take a guess. Sorry.
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
F1e2 error code
F1E2 error code usually refers to something with the control board. I do not have info before me, but believe the board has to be replaced.
Package info somewhere inside your stove will give you the explanation of that error code.
It does not hurt to unplug the stove for fifteen minutes/turn it on again and see what the error code is, if any.
Oct 19, 2013 | Whirlpool SF367 Gas Kitchen Range
F1E2 error code
F1 - E1 EEPROM checksum error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Here is the part to order.
Nov 04, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool oven
if you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
Jan 28, 2008 | Whirlpool SF367 Gas Kitchen Range
Error code F1E2
Dec 29, 2007 | KitchenAid KESC300 Electric Kitchen Range
Whirlpool Gas Oven
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
