Question about LG Electronics PA75U WXGA LED Smart Projector
I just bought lg pa75u led projector but once i turned it on, after a minute or so, it automatically shut off
Why Projector shuts down after turn on after a minutes ? and shows Temp LED and Lamp LED?
the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Aug 07, 2014 | Acer EY.JBY05.005, X1110, X1110A, X1210,...
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
LG PA70G led projector turns off automatically :(
I had the same problem .
Take off all the Inputs
Switch to another input like USB and play the projector for a while.
Then reconnect the inputs back.
This worked for me ..
Jan 24, 2013 | LG PA70G Ultra PortabProjector
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
LG Electronics PA75U WXGA LED Smart Projector Logo
220 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
