Question about Heavy Machinery
Cat 303cr mini excavator troubleshoot
I have a cat 303 cr mini ex and under hydraulic load it's trying to stall the engine? Any suggestions...hydraulic pump going out??maybe??
3 Suggested Answers
  • 4 Answers
SOURCE: 330 excavator with a c9 cat engine, heavy SMOKE
At the time you made all the above repairs, did you replace the "throw away" turbo charger? The turbo charger commonly sucks oil, and it is not repairable.
Run it without the inner & outer air cleaner. If it isn't the turbo, run the injector cut out test. If the injectors are ok, then you need to replace the injection system hydraulic pump, which is also unrepairable.
Posted on Apr 23, 2010
SOURCE: Ex-Cell EXPRO2530 w/Cat Pump. Pressure builds and stalls engine.
Your unloader valve is not wotking, get a diagram of the pump from cat and it will show what parts you need to replace, or check for blockage in the valve.
Posted on Jan 10, 2011
2002 honda civic ex ex bucking when going into passing gear sometimes stalls
Engines often misfire when going under max load conditions, due to tune up issues, bad coil, weak fuel pressure, clogged cat converter, dirty filter or injectors, dirty plugs, bad ignition module, other...
Jul 14, 2016 | Honda Cars & Trucks
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
My cat 305 mini ex run for a little while then goes dead the fuel shut off kill the engine for some reason any ideas
two units that can shut down a motor are low oil level/pressure switch/ sensor and low coolant level/ coolant temperature sensor
there may be a sensor for hydraulic pump pressure / levels
a safety sensor ---seat belt or operator bar may also be a cause of the stoppage
best have a service technician check it out
Sep 27, 2015 | Mini Cars & Trucks
121-3 runs great for 5 to 10 minute then when under load tries to stall let up on the load engine catches up change all filters this started when I was digging for 10 hour in very hard dirt
OK you've got me tricked.
The 121-3 is a Kubota number.
If this is a mini excavator, and I own big ones, this is where I would be getting my friendly QUALIFIED mechanic to check the pressures at various points and do the trouble shooting.
Aug 11, 2015 | Caterpillar Backhoe Tractor
How do I remove the engine on a IHI 35nx mini excavator to rebuild it
Undertaking that major a project, even on a "small" machine like a mini-excavator, should be done using an authorized service manual. I suspect with all of the hydraulics and other mechanicals you really want to be sure of what you're doing. If you're looking for a free service manual, I can't help except to say to consult your local dealer. An online source I found for a manual, albeit for a fee, is found here:
http://www.gciron.com/IHI_Parts_35NX_Service_Manual_Service_Manual_35NX_p/35nx%20service%20manual.htm
Dec 16, 2014 | Mini Cars & Trucks
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
Why did you do all of the engine work? Due to the same problem? Have you ran an ET on it to check for codes ?
Feb 25, 2010 | 2006 Lamborghini Diablo
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
I have an Hitachi ex40 excavator. it has started to nearly stall
I have a EX200-3 it starts but has no power. when I use any function it wants to stall. Except for the bucket function, when i use this function the engine frees up. I brought it to a mechinic but they couldnt find the problem and even made the problem worse. So when I start it up the engine sounds like there is a heavy load on it and ready to stall, this problem began and has become worse to the point I can not use the machine. Help please....
May 26, 2009 | General Garden
Heavy Machinery Logo
79 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
