Question about Sansui Televison & Video
There is only a picture in the middle of the screen, and about 3-4 inches of black all the way around it. I went into the menu, but there is nothing there even remotely close to making it full screen. Any suggestions?
    Top Expert:
  • Sansui Master
  • 74,211 Answers
Main power supply regulator fault. The output voltage that come out from it is less than normal. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Posted on Oct 20, 2013
  • 119 Answers
SOURCE: BLack box in the middle of my screen?
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
Posted on Dec 27, 2006
SOURCE: Closed Caption
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
Posted on Aug 12, 2008
  • 1779 Answers
SOURCE: black display box (nothing in it) in middle of screen
Someone has accidentally turned the Close Caption Text mode on. Go into your menu locate the closed caption section and just navigate to turn it off and that's it.... sometimes the remote may have it on there labeled CC.
Posted on Apr 08, 2009
SOURCE: Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Posted on Jun 29, 2009
  • 441 Answers
SOURCE: black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Posted on Jul 10, 2009
Testimonial: "wow its been over a year but what john said was exactly the problem. 20 seconds of figuring out where the closed caption settings were in the menu and problem solved."
This is a 26 inch toshiba lcd flat screen. the power went out for a while now I cannot get a full screen, just a black border around the edges. can you please advise me on what could be wrong, thanks will
Dear Friend: when TV is unplugged for a while, it goes into "factory default" settings. That's why you have 4:3 format of your picture settings, instead of "wide" or 16:9. check TV "screen" or "picture format" button, if it present on your TV(not a cable or satellite) remote control. If not, enter "menu" and find "display settings" and adjust it accordingly. Also: same issue might happen to your "boxes" Cable or Satellite. If those were without power for a while, same thing might happen to those. Check "menu" or call your provider, if needed.
Good luck,
Alex.
Apr 19, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Black square in the middle of screen
Jul 10, 2009 | JVC AV-36150 36" TV
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
Feb 12, 2009 | Curtis-Mathis CM19011 TV
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Televison & Video Logo
19 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
