Question about Coffee Makers & Espresso Machines
Cuisinart grind and brew grinder does not turn off
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Un plug machine .
Posted on Nov 02, 2013
SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Posted on Oct 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: I just preapred my Cuisinart to brew coffee. Now,
yes, it is.
Posted on Jan 18, 2010
Have a cuisinart grind and brew. It's not working. The power light is blinking. No other lights will turn on and/or operate. Help.
This is caused by calcium building up within the machine. or insufficient power supply.This can cause injury.Make sure you troubleshoot it or see that power supply is enough.
Jul 21, 2016 | Cuisinart Grind-and-brew 12-cup Automatic...
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
Grinder on Cuisinart Grind and brew does not work anymore.
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
The grinder does not work on my cuisinart grind n brew
I just sent an email to the following address: customerservice@cuisinart.com
explaining the problem. I'll repost here when I hear back.
Apr 17, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Mar 15, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
