Question about Samsung 7.2 CuFt Electric Dryer - DV400EWHDWR
After changing out the door from right hand to left hand, the door latches, but will not allow the dryer to start. It does not quite make the connection with the button at the top to allow the dryer to start. If you hold in on the door, it will start, but will quit as soon as you let loose. We have tightened the latch as hard as we can, but something still is not right. Can you help? We have only had this dryer 5 days!
    Top Expert:
  • Samsung Master
  • 38,077 Answers
There may be a required shim that Samsung fails to mention.
Posted on Jul 13, 2017
2 Suggested Answers
SOURCE: Re: Samsung DV419AG (gas) Dryer.... This dryer is
I just had a similar problem. The tech said that is a bad gas valve solenoid and its common for new dryers that have been sitting around for a while. The solenoid coils/springs don't get exercised so over time, the coil loses its "spring" and the valve is just loose and rattles. It was fixed under warranty at no charge.
Posted on Feb 09, 2011
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
I have 2 schlage door handles that are suppose to be able to be used right or left handed. I can't get the handle to turn to the opposite direction. (if it is set to be installed as right handed, I need...
How does the door handle even know if it is in a right or left handled door?
The handle should retract the latch with a quarter turn clockwise OR counterclockwise, so it should make no difference at all.
The only thing that is right or left handed is the direction the latch bevel points, so that it will retract when you push the door shut.
And the latch has nothing to do with the handle.
Are these circular door knobs, or is this a handle that has to then point at the hinges?
Because it seems to me that if the direction the handle points is the problem, you simply put them on the wrong side of the door.
Aug 17, 2010 | Garden
Where is the latch for opening the hood ?
The red release latch is down under the dash on the extreme left hand side. A release tongue should stick out from the radiator grill when the latch is opened. Pulling on this tongue will release the hood When you open the hood the angle is initially restricted to about 45 degrees which is fine for minor jobs. If you need extra room, the left hand hinge has a latch pin which can be swung inwards to allow the hood to move up to about 50 degrees. Releasing the second latch pin on the right hand hinge allows the hood to go vertical. You will have to release the left hand hinge latch pin to close the hood.
Jul 12, 2010 | 1988 Mercedes-Benz 300
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't start
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Jan 09, 2010 | Danby DCD5505W Electric Dryer
I can't shut my chevy Blazer door the latch is in the wrong position. How do I bring the latch back up it should be open to allow the door mechanism to slide between it locking in place.
Put a screw driver or your finger on the closed latch and sort of put a pulling motion on it,Then pull the door handle with your other hand,it will open right up for you
Dec 25, 2009 | Chevrolet Astro Cars & Trucks
Lg wd-8013c washer door latch broken. Is there an emergency release?
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
Sep 14, 2009 | LG Washing Machines
Washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Dec 28, 2008 | LG WM-2277HW Front Load Washer
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
Samsung 7.2 CuFt Electric Dryer - DV400EWHDWR Logo
37 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
