Question about GE JES1288SH Convection/Microwave Oven
Microwave when I run it, it flashes light and buzzes from the plate on the right side
    President:
  • 331 Answers
Meezy, that plate is called a "wave guide cover" and it's shorted out for a reason, (the part number is WB06X10541 and it appears to be a Factory order part). The reason it's shorted is probably due to a failed magnetron, the component used to create the microwaves. The magnetron carries a 10 year warranty from GE. Call 1-800-GECARES for a warranty repair. You'll need the complete model and serial numbers... they are on a sticker inside the microwave. Hope this helps!
Posted on Sep 27, 2007
  • GE Master
  • 9,173 Answers
Actually, in most cases, this is a simple, do-it-yourself fix. If the arcing has not been going on too long, you probably don't have any trouble with the magnetron yet. What happens is grease and/or food particles build up on and behind the cover and will eventually arc. If it is not cleaned (or replaced if damaged) then eventually it will lead to damage to the cavity and possbily to the magnetron. If the cover is held in place by a nylon rivet, carefully remove it. Then pull the cover out. Clean both sides with warm soapy water, rinse and dry completely. Be sure the cavity behind the cover is clean, too. Be careful since the metal edges may be sharp. If the cover is charred or burned, it will have to be replaced. You can find one here: http://tinyurl.com/gv383 If the oven cavity is charred, it will need to be cleaned, sanded and touched up with high temperature allpiance paint, available from most home centers, etc. Please reply back if you still have questions. I appreciate your thoughtful reply. Good luck.
Posted on Sep 28, 2007
SOURCE:
Flashing and buzzing in microwave while operating.
This sounds like carbon build up reacting to RF energy. You need to find where the burn spot is and correct it. It's probably behind or on the waveguide cover usually on the right side of the oven cavity. It looks like a brownish-tan plate about 2-3 inches by 4-5 inches. It's actually made out of mica or plastic. If you can't find the source of this problem, it may be inside the waveguide in which case the unit is not really repairable.
Oct 11, 2013 | Sharp Carousel Microwave Ovens
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
Thermador Microwave Oven Model MBBS Serial No FD 8402000337 Runs but no longer heats food. Deep growling sound Light flashes from behind 4.25 x 5.5 " metal plate on right vertical side of oven...
Oh dear, I hope the magnetron still works. That plate you describe is called the Waveguide Cover. This cover must be kept clean otherwise the food particles will carbonize and cause exactly what you have described.
Contact the manufacturers web site for a supplier in your area or look on ebay, espares.co.uk depending on your location.
When it has been changed, I hope the magnetron/aerial is OK.
Dec 29, 2010 | Thermador MBBS Microwave Oven
Kenmore microwave making loud buzzing sound.
Mar 05, 2009 | Kenmore 62622 Microwave Oven
Emerson MW8102SS - Sparks and No Heat
The magnetron tube which makes the microwaves is behind that cover plate, and it has gone bad. It is a replaceable part, but it's not worth the cost. Part and labor would be more than a new oven. It's time to treat yourself to a new oven.
Nov 03, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
GE Spacemaker XL1800 Buzzing
Chances are this is a problem on the control panel. We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Jul 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
GE JES1288SH Convection/Microwave Oven Logo
221 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
