Question about Casio FX-9860G Graphic Calculator
The x and y axis are mirrord (minus is on the right side)
  • Casio Master
  • 8,064 Answers
But is the y-axis also upside down? I tried to create such a condition bur setting Xmin=6.3, Xmax=-6.3 and a similar transposition for Ymin and Ymax. All I got is a Syntax error. I even changed the scale to be negative. Nothing doing. Syntax Error.
Now How did you do that? Show us a picture of the screen. A screen capture will do.
Posted on Oct 19, 2013
Testimonial: "Thanks for this quick respons The Y-axis is fine. As you kan see in woth pictures the X value -1 is on the right side of the Y-axis and with x=1 the position is on the left side..."
  • 2 more comments
  • Jos Smeets
    Jos Smeets Oct 19, 2013
    Sorry,
  • Jos Smeets
    Sorry forgotten to post the pictures.
  • Jos Smeets
    Problem solved.
  • Jos Smeets
    Add a Comment, The view window was set wrong. The problem occured after setting the Xmax to a negative value. Its fixed now by setting it to a positive value.
Is -7/8 greater than or less than -5/8
- 7/8 is less than - 5/8 because it is further from zero on the minus axis.
Mar 18, 2014 | SoftMath Algebrator - Algebra Homework...
My TEC SX4 has decided to do a wrap and my x-axis is offset from 0. how do i correct this problem?
The Wrap is due to the message being too long.
Inrease the width of the label. The 0,0 reference is relative to the paper width. To chage the X axis goto parameter set or adjust set depending on firmware. (X offset)
Nov 13, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Given a length of 30 cm on the x axis and a length of 10 cm on the y axis and a angle of 90 at the x/y axis intersection is there a short cut to calculate interior angles and hypot. of the triangle?
Yes, there is shortcut because this is right triangle, so you can use Pythagorean theorem (see picture).
  1. Length of hypotenuse is square root of sum of squares of lengths of other two sides of triangle, which is equal to square root of 30^2+10^2=31.6 cm.
  2. Sin(a)=longer cathetus/hypotenuse=0.949 so a=arcsin(0.949)=71.6 degrees
  3. Finally b=90-a=18.4 degrees.
If this was helpful please rate 4 thumbs :)
Sep 05, 2011 | Texas Instruments TI-30XA Calculator
I have this different type of graph, it is onle showing the right side of my graph...I can only see the positive x axis. How do I change it to the full graph, where I can see the positive and negative x...
Press MODE to bring up the mode screen. Use the arrow keys to highlight "FULL" on the eighth line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Feb 03, 2011 | Texas Instruments TI-84 Plus Calculator
How to I make it run at 2 channels, 2ohm per channel to get the 250 watts per channel?
If you are looking at the termianl side of the amplifier...you have on the left hand side a plus and minus, this will be the left speaker........the next terminals are the line in from thr radio head unit (RCA), then plus and minus for the right hand speaker. This is the basic setup for a 2ohm , 250W RMS output......please make sure to attach plus and minus to plus an minus on the speaker and not get them mixed around.....you WILL notice the difference
Sep 20, 2010 | Sony XM-SD22X Car Audio Amplifier
What is the answer to 10x minus 3x equals 20 plus 1 equals what
joshua,
X = 3 (answer)
Here are the solution steps:
10X minus 3X is 7X (right?)
20 plus 1 is 21 (right?)
therefore:
7X = 21
now divide both sides of the equals sign by 7
7X divided by 7 equals 21 divided by 7
7X / 7 = 21/7
X = 3 (answer)
More math? Ask for Gort007
Thanks for trusting FixYa !
Sep 14, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Admission to a professional course is subject to the following condition: a) Marks in mathematics > = 60 b) Marks in Physics > = 50 c) Marks in Chemistry > = 40 d) Total in all three subjects >...
So:
X >= 60
Y >= 50
Z >= 40
Take 51 sheets of "graph-paper" (1+200 minus 60 minus 50 minus 40).
On the first sheet of paper, label the graph-title as 'Z=40'.
Label the X-axis from 60 to 200.
Label the Y-axis from 50 to 200.
Draw a straight line from (X=60 and Y=(200-60-40))
to (Y=50 and X=(200-50-40)).
On the second sheet of paper, label the graph-title as 'Z=41'.
Draw a straight line from (X=60 and Y=(200-60-41))
to (Y=50 and X=(200-50-41)).
On the next sheet of paper, label the graph-title as 'Z=42'.
Draw a straight line from (X=60 and Y=(200-60-42))
to (Y=50 and X=(200-50-42)).
On the second sheet of paper, label the graph-title as 'Z=43'.
Draw a straight line from (X=60 and Y=(200-60-43))
to (Y=50 and X=(200-50-43).
Keep going for all 51 sheets of graph-paper.
Stack the 51 sheets on top of each other,
to visualize the "3-D" solution to the problem.
P.S. Don't tell your school-teacher that I helped you do your "homework".
Nov 04, 2009 | Microsoft Computers & Internet
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Logitech controller incompatible
go to logitech profiler> right stick X-axis>axis properties>map to x-axis drop down menu pick mouse x-axis then repaet the step for the y-Axis.
Jul 22, 2009 | Logitech Dual Action for Pc (963292-0403:)...
My controller works but I cant look around w/ it?
So you mean the Dual action is supported by default in Oblivion? Or did you set up commands using a profiler software? I am familiar with Logitech Game Profiler so I will tell you what you need to in it.
Left click on "Right Stick X-axis" -> Axis Properties -> At the bottom, "Right Stick X-Axis mapped to", choose Mouse X-Axis.
Now do the same for Y axis. Works in every game.
Nov 21, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Casio FX-9860G Graphic Calculator Logo
70 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
