Question about Cub Cadet Garden
Oil leaking around oil pressure switch - Cub Cadet Garden
    Novelist:
  • 212 Answers
Next time you change oil, unscrew switch, get some plumbers tape and wrap around threads a couple times and screw it back in. This should fix it.
Posted on Oct 19, 2013
Oil pressure switch
Hi Jerome...
Replace the switch, it is defective
Bud
Oct 19, 2013 | Cub Cadet Garden
Pt cruiser is using a quart of oil every 100 miles
Should be a leaking oil pressure switch.
First, check to oil filter, area to see if the oil is obviously coming out around the filter. Filter and area around it should be dry,.
There has been rare instance of the "o-ring" on the top of the oil filter sticking to the engine when the filter was changed, and the new oil filter then won't seal because there are now 2 gaskets between the filter and the engine block.
Check the engine drain plug. Is it loose or stripped? That area should also be clean and dry.
The valve cover gasket should be clean and dry all the way around.
Most common cause for that much oil use is the oil pressure switch, should be leaking with the motor running.
Jan 04, 2013 | Cars & Trucks
97' Honda Accord is leaking oil around where the oil filter is located. there is no extra gasket there.
Above the oil filter is the oil-pressure switch for the light in the cluster. That's a sorta-common source of leaking. Oil leaks directly through the defective switch, coming out around the rubber boot where the wire attaches.You didn't state what size engine you have so I will send you a link to both engines that is listed for the 97 model. Duralast Oil Pressure Switch PS100 Read 1 Reviews on Duralast PS100 here's the one for the 6 cylinder. Duralast Oil Pressure Switch PS309 Read Reviews on Duralast PS309
May 29, 2017 | Cars & Trucks
I have a very bad oil leak around the pan of a 1997 mazda protege. where else could oil be leaking form.
you could have a bad oil pressure switch leaking oil,oil pan gasket,rotted out oil pan,head gasket leaking oil and running down the block.
Jul 04, 2011 | 1997 Mazda Protege
Whats the purpose of an oil pressure switch can it determine weather oil leaks from your grand prix or not?
The oil pressure switch or sending unit is a unit that receives an electrical signal showing what your cars oil pressure is.And yes it does partially does let you know when there is a problem somewhere in the oil system.For example if your filter gets clogged up your oil pressure will go down and then go up when you accelerate.If there was a leak in the system first you would probably see the leak And if the oil pump or oil pump shaft were to break you would have no oil pressure.So you can see the importance of having an oil pressure switch.I feel there are 2 guages that are important to watch are your oil guage and water temp guage they can tell you allot about how your car is operating.
Feb 09, 2011 | 1997 Pontiac Grand Prix
Leak around oil pressure switch on ford taurus 1994
the internal seal has gone ,renew the switch
Dec 03, 2009 | 1994 Ford Taurus
Oil
bad oil pressure sender unit.or low oil pressure.put a pressure gauge and measure it.check for oil leak around oil pressure sender
Jul 13, 2009 | 1998 Toyota Camry
Massive Oil leak near the oil pressure switch
did you put teflon tape on the oil switch threads?
May 15, 2009 | 1996 Dodge Intrepid
Oil leaking from some sort of plug above the oil filter
If the leak is coming directly from above the oil filter it is more than likely the oil pressure switch is leaking. The seal around the Oil pressure switch could have gone bad and now it is leaking.
The oil pressure switch is located right above the the oil filter and above the cooling system cross pipe.
Dec 13, 2008 | 1993 Honda Accord
Garden Logo
29 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
