Question about Sanyo PDP-42H2W 42 in. HD-Ready Plasma Television
Blue vertical lines
Blue lines just started to show up on the screen, at first they would come and go, but now they always come up after the television has been on for about 2 hours. Does it have to be with the heat produced by the screen? I haven't disconnected anything from the TV since I first installed it, I purchased it about 10 months ago. Don't use it for playing video games just satellite and DVDs.
  • sseidel Dec 08, 2007
    We just set up a new Sharp LC46D92U and it worked perfectly for about three hours. Then a thin vertical blue line developed originating just left of center and extending from the bottom to half way up the screen. Sometimes the blue line is constant and sometimes it comes and goes. Please advise. I have written Sharp and my seller today (12-07-07) and am waiting for a response. Any ideas?
  • onejoehill Mar 12, 2009
    blue vertical line appears, then transitions to a vertical strip of about 2 inches wide, then the strip sometimes changed to yellow
  • 661 Answers
Check with the manufacturer, this sounds like a problem with decoding, or maybe the screen driver. as this is 10 months old it should still be within Manufacturer's warranty and they should sort it out for free :)
Posted on Sep 27, 2007
SOURCE:
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
My screen suddenly shows blue and pink vertical lines
Sounds like the gel has dribbled down into the workings and has effected the circuitry. Time for a new monitor. More importantly, why the heck were you using a liquid/gel sanitiser on electrical equipment. Use dedicated screen wipes
Sep 27, 2017 | Computers & Internet
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Blue vertical line on my desktop
The blue lines are a sign that the screen itself is failing. You can try to reseat the data cables from the motherboard to the back of the screen, but in most cases this is indicative of an immenent screen failure.
Jan 13, 2010 | ASUS G1SN-A1 Gaming Notebook PC
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Sanyo PDP-42H2W 42 in. HD-Ready Plasma Television Logo
395 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
