Hoe do I turn a feh-010/012 intertherm ultraflex
Hoe do I turn a feh-010/012 intertherm ultraflex heater on
hotuna
  • 288 Answers
SOURCE: intertherm ultraflex mobile home furnace
Is this a 120v motor, or 220v? If you checked for power, I assume you kind of know your way around a meter. When checking for power, don't check to ground, check the line. You could have power going in, but unless its going back out, completing the circuit, or missing a leg, in 220v case, it still will not work. Also, most heaters have some sort of delay, so after you hook it back up, and the burner heats up wait a few minutes for the fan to come on.
Posted on Dec 31, 2007
SOURCE: heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Posted on Mar 14, 2009
  • 659 Answers
SOURCE: i have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Posted on Mar 17, 2009
flatech
  • 111 Answers
SOURCE: I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
Posted on Oct 24, 2009
  • 414 Answers
SOURCE: 1985 intertherm ultraflex needing a
intertherm units were used in many mobile homes. you can google mobile home supply
companies and should be able to find the replacement. Hope this helps.
Posted on Jul 08, 2011
Have 84 model feh-015ha heater comes on but motor wont start
should come on with first stage heat bad sequencer or motor.
Jan 30, 2014 | Intertherm E3EB010H Electric Furnac
Intertherm Feh-015HA
Sounds like a bad contactor in the circuit. They are usually power to close (on) and spring to open (off) so it should go off automatically. A tech can open unit find right relay and replace it or try contacting these folks with your serial number:
http://www.furnaceparts.com/Store/Category/Intertherm.aspx?page=4
Nov 13, 2013 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
1985 intertherm ultraflex needing a filter for the bottom door to the unit its about an inch thick and looks as if its never been cleaned or replaced Where do I purchase a new filter??
Jul 08, 2011 | Intertherm Heating & Cooling
Disconnect assembly has overheated and needs replacement. where can I find a new puul-out disconnect assembly for my intertherm furnace model FEH-015HA-03
Those parts are readily available. You can get them at intertherm.com or google hvacparts.com and have your model and serial number ready. You are talking about the pullout at the bottom left of the unit correct. If you have a breaker within six feet of the pullout you can remove it. But be very careful and turn off all power before you try.Rus
Dec 04, 2009 | Heating & Cooling
I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE IT IS A INTERTHERM MODEL FEH-015HA-04 NOROYNE SERIAL FEH 9105-00229
Oct 21, 2009 | Intertherm P3RA-048K Air Conditioner
Heater furnace doesn't want to turn on'
Mar 14, 2009 | LG L1004R Air Conditioner
Blower will not shut off on furnace. I have a Intertherm FEH-015HA Central Electric Furnace
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
Feb 20, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
