Question about Sewing Machines
White 1099 sewing machine. Needle and handwheel do not move after filling bobbin. I recall hearing something fall when I disengaged the wheel. How do I repair it? What did I do wrong?) (Where can I find a repair manual?)
  • Sewing Machines Expert
  • 458 Answers
I don't know this make but if it is NOT electronic you could try using a magnet to remove whatever fell in. Or turn it upside down and shake it out. Sounds like it is stuck in the mechanism.
Posted on Oct 19, 2013
4 Suggested Answers
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
  • 1788 Answers
SOURCE: I have a kenmore sewing
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Posted on Dec 24, 2010
WhenI turn the inside nob the needle works but not when I turn the outer nob, it just turns and nothing happens WhenI use the peddle the outernob spins but again the needle doesnt work (nob=handwheel)
On most machines, when the inner wheel is turned counter clockwise, it engages the bobbin winder and disengages the needle movement.
To disengage the bobbin winder and sew, turn the inner wheel clockwise as far as it will go. This should engage the sewing capability and it should work either by hand rotating the large wheel (always counter clockwise!) or with the foot pedal. If it does not, then you most likely need to have your machine serviced.
Jun 29, 2016 | Sewing Machines
Sewing machine hand wheel stops needle when it should be working and vice versa
Hi, the link below is a youtube instruction video for a brother sewing maching, Also there's other brother video's you can click on down the right side of page..... I hope this helps...........CHEERS..
Brother Sewing Machine Instruction Video
Apr 03, 2016 | Brother Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
How to fill the bobbin
sorry no make nor model we don't know who to ask
Mar 15, 2015 | Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
I have a White 1099 sewing machine. Several years ago, I interrupted a project to fill a bobbin. After I filled it and re-tightened the handwheel, neither the handwheel nor the needle moved when I...
.... if it was sewing fine before the bit 'dropped off' it probably doesnt need the other thing done - they just are standard type check / adjust things done with a service. Weigh up how much a new machine will cost you v the repair. How happy are you with it? How often do you use it?
I am not familiar with this model, but the 'clutch' is generally a very simple setup. If you feel confident and can get the end cover off , have a peek - find the bit that dropped off ......
The only tension you should need to adjust is the bobbin tension - which I am sure you already know how to. Top tension is normally just a clean out of fluff etc.
Oct 19, 2013 | Sewing Machines
Have a singer 3221/3232 cannot disengage handwheel to fill bobbin what am I doing wrong
Are you sure you have to pull or push? It looks to me like you just slide the bobbin winder spindle to the right to engage.
Here's a manual for your machine... I'm sure more specific info is in there.
http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf
Nov 08, 2012 | Singer 2263 Mechanical Sewing Machine
I plugged in my machine after it had been sitting idle for about a year. I have power and can hear the motor turning, but the needle doesn't move. It acts like a 'clutch' has been disengaged....
does sound like machine is in bobbin winding mode. The clutch may be disengaged by an inner wheel on the flywheel, flicking the bobbin spindle over or a button.
Best thing is to check the manual for your machine as they all vary. Go to http://www.singerco.com/accessories/instruction-manuals/search
then type in the model number with a w in front and click search.
The White and Singer manuals are listed here and many are free downloads as pdfs.
I hope this helps you out.
May 30, 2011 | White Sewing 2037 Mechanical Sewing...
Threading the bobbin, disengage the needle
Depending what brand and model of sewing machine it is, you can usually disengage the needle bar with the knob inside the handwheel by turning it towards you. If you've done that and the needle bar still moves, it needs oil and should be serviced by a technician.
Feb 24, 2010 | Sewing Machines
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
