Question about Samsung SCX4824FN Mono All-in-One Laser Printer
Mp c2500 error code sc452 - Samsung SCX4824FN Mono All-in-One Laser Printer
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
WHAT IS ERROR SC 397?
the colour drum drive is overloaded.... probably one of the drum units has siezed
Dec 01, 2014 | Ricoh Mp C2500
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
Code sc 101 mp c2500
Optics problem check to see if mirrors are dirty. Will need to clean mirrors be carefully you can cause mirrors to fall out or become miss align . Buy a can of air blow them off . Turn off copier before you start then turn on and copier will move optics back into position.
Jan 15, 2014 | Ricoh Aficio Mp C2500 Copier
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Jul 02, 2010 | Audio Players & Recorders
Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
Apr 24, 2009 | Kyocera Office Equipment & Supplies
Samsung SCX4824FN Mono All-in-One Laser Printer Logo
102 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
