Question about Stanton ST-150 Turntable
The 45rpm speed select button will not work
Hello, i have recently found that my 45rpm speed select button has been faulty, on and off. Now it is not working 100% of the time. Do you have any possible causes for the problem, and any possible methods to fix this problem? Can I try to pop off the button and then investigate from there? Or is this button not designed that way ? thank you very very much for any help you may have. Sincerely, Grant
    Novelist:
    Champion:
  • 382 Answers
The 45 button is known as a push button switch. If the switch is affect, replacing should remedy, but it could be possible that the voltage variation on the motor is affected.
keep me posted.
Posted on Oct 28, 2007
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
Have just resurrected a Kenwood KD-56R turntable from 15 years ago, most of it functions fine but it spins too fast. Its direct drive, and i have tried adjusting the potentiometers for both 33 & 45rpm,...
I suspect that a fault has occured on the section that controls the speed of the motor. Perhaps an IC failure. If you have a look at any of the IC's on the motor board you could note down the numbers and look around on the net to see if they might give you clues to what they do, plus what they cost to replace or if they are obselete.
Mar 28, 2010 | Audio Players & Recorders
The jukebox powers up but the buttons wont work
Is this a CD player or 45RPM? Is the display lighted? What is the display showing? The answers to these questions will help narrow down the problem. For additional assistance please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Manual Operation
It should work with the remote by holding the forward or revese buttons while using. To increase speed press the ff or rev buttons again.
Oct 26, 2008 | Durabrand DVD-1002 DVD Player
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Turntable speed
most of these were belt driven, if that the case check to see if the lever is connected moving the belt to the slower pully
Dec 31, 2007 | Sony PS-LX250 Turntable
Open Questions:
Stanton ST-150 Turntable Logo
205 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
