Question about LG Dryers
Just bought LG gas dryer, was a floor model and I didnt get the manual with it. when I set the dryer, it seems to be on a timer because I will set it for 54 min and about 5min later the dryer will turn off. The cooling light is on and I think thats whats the matter but I dont know how to turn it off....Ant way you can help me! Thank You, Dottie
    Novelist:
    Scholar:
  • 100 Answers
Take off your LINT Ducting and clean out completely, all the way to the outside hole in your house.
There is a heat limiting switch that turns off the unit if the heat gets to a temperature in the Lint Duct that is too high and is very dangerous.
If the air flow is limited too much, then the free flow of air can not be carrying out the heat generated by the machine to dry the clothers. You could have, and probably do have a nasty clog in your ducting, so hence, the air is not getting out successfully and it is staying all in the dryer unit. When the temperature reaches the LIMIT ALLOWED, then it shuts it off to prevent a instant FIRE.
The good news is your sensor is working, and the bad news is you gotta take the ducting apart and clean it good.
HINT: Make sure you DO NOT have any loops or low spots or lengths of hose that make the dryer have to blow the lint UP HILL. That is a common mistake because damp lint is heavy and it will build up anywhere there is a place that the air flow will not carry the weight of the damp lint, hence it drops it right there and starts a build up until it is blocked and then the sensor feels the temperature reach the Upper Limit and shuts off your machine. You may have to reroute your dryer ducting in a manner that the air flow is always level or even better, slopping down a little.
Good luck, and be sure to unplug the dryer before you start digging around the back and/or inside your machine.
kindly,
Jim
Posted on Oct 20, 2013
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
SOURCE: HotPoint Dryer Model Number NVLR333EVOWW not getting hot
Set the timer one day, later clothes not warm at all, dryer still running and timer had not moved. It has never heated up again. Can you help me figure out the problem? Where all the heating elements, thermostats etc may be. thank you for your help.
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Posted on Aug 25, 2009
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
I have an older model...........maybe 8-10 yrs and i turned it on lastnight and this morning it was still running. the knob that is like the timer didnt even move???? i opened it up and the clothes were...
The gas turned off when the temperature is detectd by a thermal sensor. The timer is not working therefore the motor keeps running until you turned it off. The timer need to be replaced.
Apr 27, 2010 | Kenmore 72602 Gas Dryer
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Jun 08, 2008 | Dryers
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
32 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
