Question about GE Profile PT970DRWW 30" Combination Double Electric Wall Oven with 4.4 cu. ft. Lower Oven Capacity, PreciseAir Convection System, Convection Bake/Roast, Black Gloss Oven Interior, 1.6 cu. ft. Microwave, 1,000 Cooking Watts and Turntable: White on White
Microwave panel not responding for GE PT970S M2SS
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
Ge microwave touchpad has power but will not respond to finger pressure.
Then the only thing you can do is replace the control panel, most likely it is better to just replace the oven cost wise
Jul 14, 2017 | GE Microwave Ovens
Micro is three, front panel not responding
If I understand you, the front keypad is not responding. In that case you will need to replace the keypad control board.
Apr 08, 2012 | GE Spacemaker JVM1540 Microwave Oven
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave oven does not have power to the panel.
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Jul 02, 2009 | GE Spacemaker JVM1750 Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave spacemaker startrs running automaticvally and won't respond to rest off buttons
reset the control panel/trest again same thing happened, if the same something wrong IC progaming.
Jan 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile PT970DRWW 30" Combination Double Electric Wall Oven with 4.4 cu. ft. Lower Oven Capacity, PreciseAir Convection System, Convection Bake/Roast, Black Gloss Oven Interior, 1.6 cu. ft. Microwave, 1,000 Cooking Watts and Turntable: White on White Logo
71 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
