Question about Whirlpool Duet GHW9150P Front Load Washer
FH Code on my duet. I have also had a SUD problem this week. I checked pump, flow meter and inlet. We recently changed not only our detergent, but also went with a lower cost solar salt. Does anyone think these things could be related? It just seems that the timing of this is just too odd. I am switching back to the old stuff to see if that will change things. Any comments . . .
    Sergeant:
    Champion:
  • 257 Answers
You should check the pressure switch. Normally, the error code is F25 but sometime is said SUD. You may need to replace it. The another part you should check is the hose connected from dispenser to the drum. Good luck.
Posted on Oct 22, 2013
  • 249 Answers
SOURCE: Duet Washing Machine model ghw9100lw1 FH ERROR CODE
you should here a humming noise, just before water comes in .do you?close eire let me know.
Posted on Dec 07, 2007
Master_Tech
  • 770 Answers
SOURCE: f h code on duet
FH= No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Apr 24, 2008
IB4G2008
  • 3587 Answers
SOURCE: Whirlpool Duet washer FH code "sometimes"
well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Posted on Jun 04, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
Posted on Jan 16, 2009
  • 170 Answers
SOURCE: SUD Code appears on Whirlpool
sud means over suds are you useing he soap maybe too much.......
Posted on Mar 24, 2011
FH error code frustration
Replace main control board and pressure switch together .
May 26, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer estimated time remaining flashes h followed by f
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Nov 29, 2012 | Whirlpool Washing Machines
Hi Expert, I have the 9200 Whilpool Duet washer that is now stuck in the rinse cycle and is 1/2 full of water. I tried to drain it by lowering the hose into a pail but no luck. I get the FH code. I have...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have Duet front load washing machine and over the last 7-8 years have battled he FH code.I have opened the machine numerous times, tried to flush and back flush the water valves/solenoids gone back and...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
Potential Causes
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer giving error code FH begins cycle filling with water then stops and only get humming and no more water and finally the error code
Or
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Dec 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code FH during wash cycle.
Hello,If there is water in the unit:
1. Check the drain pump operation
2. Pressure switch hose is in good condition and properly connected to
*Tub and pressure switch
*check there is not a siphon problem
*check wire harness connection to inlet valves,pressure switch,drain pump,flow
*Meter, and central control unit(CCU)
*check all hose for possible leaks
*check pressure switch operation
*check flow meter operation
*check CCU operation
Thanks
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front loader is saying error FH ? Do you know
Here's the FH troubleshooting guide
or check out link go to this
http://www.repairclinic.com/0078.asp
WHIRLPOOL
Duet & Duet HT Failure
Code
Condition Check/Repair F/H No water detected entering machine or Pressure switch trip not detected.
Or
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Mar 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get a fh every time and have followed instrutions that my customer has recieved
The FH indicates that No water detected entering machine or Pressure switch trip not detected.
Or
ACTION
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Or
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
