Question about Pool & Spa
I bought a FreeFlow hot tub from a friend. The pump just continually runs for 15-20 seconds then shuts off. The temperature also is not rising, I can't seem to get it to work properly no matter what I do. I've tried everything in the owner's manual. Does anyone have any other suggestions? I'd really like to be able to use the hottub and not get rid of it.
Its the heater coil..... same thing happened to me... easy fix
Posted on Jan 17, 2014
    Scholar:
  • 94 Answers
Thanks for your question. A hot tub is one of those items I personally do not recommend purchasing used, unless from a reputable dealer that can provide some type of warranty or service contract. I only say this because it\'s possible for them to have many many problems indiscernible to the naked eye.As for your particular hot tub, are there any error codes on the topside display? when the tub shuts off does it trip the breaker as well? it sounds as though there may be a problem with the circulation pump or possibly one or both of the heat sensors. it could also be the heater itself is not functioning properly and this is causing the system to shut off. Unfortunately, without more information, or looking at the tub I cannot tell you which of these to troubleshoot first. The only other option I can think of is to call a service technician to inspect the tub,a service call runs about $60-$90 per hour, If you could give me the error code(s) readout from the topside we could establish a starting point, otherwise we\'re just flying blind & I don\'t want you to spend money replacing parts that still work. If you can post again with an error code I\'d be glad to go from there, I\'m sorry I couldn\'t help more...
Posted on Nov 09, 2013
  • John Chorko
    John Chorko Jan 17, 2014
    its the heater coil..... same thing happened to me... easy fix
2 Suggested Answers
  • 368 Answers
SOURCE: i have a freeflow legend hot tub. the gfi was
It sounds like there may be a short in it causing the breaker to trip. I would disconnect the wires from the new element, tape them up and test for the problem again. If it still trips it is not related to the heater element. If it still trips it is not related to the heater element and therefore additional diagnostics need to be used to find out what is is wrong.
Posted on Sep 06, 2011
Why does 2000 s40 volvo turbo runs hot and the fan stays on after shut off
fans are designed to run on after you shut engine down as engine temperature rise after switching off . running hot could be caused by the top hose having gone soft when you rev the engine the water pump sucks the hose flat stopping the coolant flow or the radiator is blocked and need flushing out
Sep 16, 2014 | 2000 Volvo S40
Hot tub pump running unexpectedly
check the heater setting.. it may be the heater demanding cooler water to go through..it will cycle as needed by the heater..
Dec 27, 2013 | Pool & Spa
Sunlighter hot tub
Sounds like the pump motor is tripping out on thermal overload. Touch that particular motor just after it shuts off. If it is "very" hot to the touch, it probably needs replacement.
Oct 16, 2013 | Electrical Supplies
It doesnt want to start butn once running its fine
Hot starting problems are usually fuel related. When a hot engine is shut off, the temperature of the engine and everything on it continues to rise for awhile as the engine undergoes a period of "heat soak." This can cause fuel to boil inside the carburetor bowl, fuel lines and fuel filter. When you attempt to restart the engine, "vapor lock" obstructs the flow of fuel and the engine doesn't want to start.----------------------------------------------------------------------------------
Digiprog3
Dec 20, 2012 | 2005 Dodge Neon
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
KENMORE DISHWASHER CLEAN LIGHT BLINKS SEVEN TIMES M#665.17029403
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher run normal but the fault will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine either with extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 03, 2009 | Refrigerators
Temp in hot tub dropped from 40 to 35 and motor making a little noise
the bearings at the motorworn out due to a leak must bring to a professional to replace the bearings or replace the motor or pump. be more especific about the change on the temp
Aug 30, 2009 | Optimus FREEFLOW SPA HEATER, 4 KW, 240
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Pool & Spa Logo
82 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
