I took the squirl fan out of ac to clean and when i put back in the ac will work but when switch to heat the fan wont blow
  • 52 Answers
Make sure you give it time. The fan has a time delay in heat mode and doesn't come on until it warms up first.
Posted on Oct 28, 2013
  • 56 Answers
SOURCE: Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Posted on Feb 16, 2009
farfield
  • 462 Answers
SOURCE: Heat Pump and fan work fine, but will not blow
The reversing valve coil may be bad or no power to it during cool. Most heatpumps are set to have the coil of the reversing valve energize in the cool mode. The heating mode is the fail safe mode if the rev valve fails to energize. Check this and let me know.
Posted on Jun 20, 2009
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 788 Answers
SOURCE: I changed my fan motor and squirl cage blower
If you have changed the motor, I assume that the RPM is the same as the motor you have removed.?
Check the rotation of the new motor, if you have it turning in the wrong direction, it does not matter how fast it turns, it will not send enough air across the evaporator and condenser coils.
Also, if you have changed the motor, you should also change the run capacitor for the power motor.
Hope this info has helped you.
Posted on Oct 08, 2009
mcdevito75
  • 1970 Answers
SOURCE: Ac turns on and the fan blows air but not cold
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Posted on Jun 24, 2010
Fan wont change from low to high on GE heater/ac unit
clean blower and coils , check out fan motor and fan capacitor .
Nov 09, 2014 | Heating & Cooling
Coleman furnace problems
I take you mean there is a fan coming on that blows AC air thru the vents and is the same fan used to blow the heat ? If that is the case is the fan coming on when the heat comes on ? If not then that is why you are not getting the heat.
That can be from a temp sensor not working or a control board or a contactor
First see if the fan even comes on or if the same fan is used for both AC and heat
Oct 13, 2013 | Heating & Cooling
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
Coolant fans not working can overheats when driving slow
did you get any obd codes ?? well there is a possible the power relay or ac relay is not working.
Sep 24, 2012 | 1999 Pontiac Grand Am GT
The cooled air is coming out at a very weak rate. The ac unit outside is blowing out cool air when the neighbor's is blowing out warm air. The house is just not getting cool. AC has been on for 4 days...
Turn off your A/C and put your fan switch in ON or FAN. Run the fan only for approx 3 hours. Check your air filter and clean/replace as necessary. Also check your evaporator coil and clean if necessary. It is possible that your evaporator coil is frozen up from a dirty filter or coil. If it continues to be a problem, you probably have a refrigerant problem which will require a certified service technician to address. Try taking care of the filter and coil first. :-)
May 28, 2010 | Honeywell Electronic Programmable...
06 Chevy Suburban Dash fan stopped working
this is because you have a bad switch which has gone bad and you need to replace it or either try to bypass it through another circuit.
Jul 25, 2009 | 2006 Chevrolet Suburban
Heater control wont heat. AC and fan works fine
mechanical or vacuum operated valve that releases hot coolant into the heater core may be stuck closed. or the heater core may be clogged. hope this helps.
Aug 10, 2008 | 1997 Pontiac Bonneville
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
