Question about Stihl 029 039 Ms 290 310 390 Chain Tensioner
Replacing chain tensioner on a stihl 029 chain saw
  • Stihl Master
  • 1,807 Answers
dontbother10
  • 2220 Answers
SOURCE: I need an owners manual for a Stihl MS180 Chain
Hello Dave;
An OM for your saw can be found at this link:
http://www.stihlusa.com/stihl_ownersmanuals/MS170_180_Manual.pdf
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 13, 2010
dontbother10
  • 2220 Answers
SOURCE: where do I find a operating manual for my STIHL
Don't believe everything you read.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
This was returned from my attempt:
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
IPLs (parts lists) are proprietary and not available to anyone not a Stihl dealer.
Lou
Posted on Mar 22, 2011
  • 6468 Answers
SOURCE: Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Posted on Apr 15, 2012
  • 6468 Answers
SOURCE: stihl chain saw quetions
sounds like you have been tightening the chain to tight
Posted on Sep 08, 2012
yosemyt
  • 322 Answers
SOURCE: air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Posted on Mar 20, 2013
I have an stihl 029 super chain saw that the spark plug won't stay in it. What parts do I need to fix it?
If the threads are crossed, stripped or loose, you need to take it to an engineering place and have a 'helicoil insert' fitted, this is a new steel insert that is tapped and threaded into the head after the hole has been enlarged a little.
helicoil insert Google Search
Dec 12, 2016 | Stihl Garden
Engin parts for 029 super stihl chain saw
perhaps a STIHL dealer can assist you .
Dec 09, 2016 | Cars & Trucks
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I can't tighten the chain on my stihl ms 251 chain saw
Pull the side cover and check for a broken or misaligned chain tensioner. I assume that you have loosened the bar nut on the side cover before attempting to adjust the chain tension. The methiod varies depending on whether your model has the side chain tensioner or the quick chain tensioner.
Dec 08, 2013 | Stihl 029 039 Ms 290 310 390 Chain...
Oil not goingg to the bgar
Have you cleaned the oiling hole in the guide bar.? Scrape out the full length of the guide bar using a cleaning tool. There is an oiling hole at the back of the bar on either side which the oil flows into.
Is oil being pumped out the saw.? Remove side casing and guide bar, run the saw and check the flow.
Feb 17, 2013 | Stihl 1127 Control Shaft 039 310 290 390...
Saw will start and run but chain wont turn
Chain brake may still be applied.
The chain brake is the front hand guard, pull it towards you to release the safety brake. Check chain tension, the chain may be too tight.
Sep 30, 2012 | Stihl Used Ms290 Ms 290 310 390 029 039...
Too much oil
An Instruction/Owner's Manual can be found here:
http://www.stihlusa.com/stihl_ownersmanuals/STIHL029_039_with_safety_manual.pdf
There is an oiler adjustment that is explained on page 33. HTH
Lou
Jan 01, 2010 | Garden
Replacing the fuel vent hose on a Stihl chain saw
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Nov 19, 2009 | Garden
Stihl 029 039 Ms 290 310 390 Chain Tensioner Logo
206 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
