Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows XP sp 2 not installing
Sir, i have been for quite a long time to windows XP in my PC but in vain. earlier than this while working on something or listning or watching to music it suddenlly used get restarted automatically. and when it opens then it would show a message as "the system have recovered from serious error". so i tried to install XP again but in vain. help me to solve this problem. from Ajay
    Novelist:
    Scholar:
  • 167 Answers
It is hard to suggest a simple solution. If the reinstallation of WinXP went smooth and problems are back again....the problem might be in the hardware. Suggestion-0. Download the latest drivers for your hardware and install them, after you install WinXP. Run an antivirus program that upto date do a complete system scan. I would recommend Trend Micro's PC-Cillin or Mc Afee antivirus. Suggestion-1. I suggest you to check your memory modules. I f you have two RAM modules: pick one out and start the system. Now if there is no problem. The RAM in your hand is faulty. Otherwise reinsert the RAM in your hand and pick the other one out. Now start the system. If it works well replace RAM in your hand. Suggestion-2. Seocnd thing is your hard disk. If you can take out and put your hard disk in a different system and reinstall windows if it fails to start. And see if the problem persists. If so, change your hard disk. Suggestion-3. Next thing is the motherboard. This is a tedious job, I do not encourrage to do this. carefully inspect the motherboard for leaking capacitors. If there is any take it for warranty service (if applicable) or you can ask some one to change the capacitors. Suggestion-4. Check the power supply module(SMPS) Make sure all connctions are intact and no loose connction exists. (This may be threat to the circuits). If you can arrange a spare SMPS, try connecting that. Suggestion-5. Check your power cables. If you have spare cables try changing that. Some cable are low quality and may get short & spark.
Posted on Sep 27, 2007
  • Deepu Amalan
    Deepu Amalan Sep 27, 2007
    This is a complicated problem, so is the solution. So try to isolate the problem by cross checking between other machines if possible. Thank you
How can i run 16-bit program on 64-windows
First I would try right clicking on the installer and going to the compatibility settings and changing the installer to use windows xp sp 2 or earlier and do the same once the program has installed. If that doesn't work Installing XP mode into your system would probably your best bet but that would take some pretty decent hardware on your system to run cleanly.
Nov 20, 2013 | Cosmi Flow Chart Maker Full Version for PC...
How to boot from USB
Sir
first time restart pc sudden press boot menu>set first boot USB cd rom press f10 key save
Oct 19, 2011 | Compaq Computers & Internet
Dear sir i want to know that how could i install new windows in my Dell Latitude C400? I've searched many sites but in vain. Plz sir help me. I am waiting thanks
If by "install new Windows" you are asking if you can install Windows 7 on this computer, then the answer is no. This computer was designed for XP and the hardware will not support Windows 7.
Jul 30, 2011 | Dell Latitude C400 Notebook
My pc is shuting down automatically after displaying error message as "c:\windows\system32\services.exe", i am using windows-xp sp-2 OS
you have a virus.the clue is in servicesEXE.boot to safe mode
go to start/accessories/system restore/ and restoreto earlier date.
or you could try a viral re mover if these fail install fresh windows
Aug 15, 2010 | Computers & Internet
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Nov 07, 2008 | Microsoft Windows XP Professional With...
Can't instal xp on compaq vt 3717
its the feature of microsoft that it would not let install win xp on a computer with vista. what u can do is completely format the computer and use bootable xp cd and install .
Nov 02, 2008 | Compaq Presario Notebook
No sound from the system
i don't have sound on my PC, I think that the realtek sound manager don't work properly... please help me.
Jul 18, 2008 | Compaq Ensoniq AudioPCI Sound Card
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
