Question about Fisher and Paykel Dryers
Sensor bar Upper moisture sensor bar came loose from bracket in my top load dryer. I can't figure out how to put it back into the bracket correctly so that it will line up with the cover. I appreciate any help. Thanks!
  • Cathy
    Cathy Oct 19, 2013
    Well, I ended up taking the top cover off of the dryer so I could get lower and line up with the brackets better. It popped right in! Thanks for viewing my question!
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Moisture Sensor
if you can get it to go back in sure why not,its simply a metal strip plugged in to a wire measuring resistance, so if its not physically broken you should be able to pop it back into place
Posted on May 12, 2008
SOURCE: Kenmore Elite Turning Off before clothes are dry...
Repair of a Kenmore Electric Dryer Model 110.62942100
Dryer not heating
I just spent several hours repairing my electric clothes dryer, and wanted to share my experience with others that may wish to do a similar repair. Some of my time was spent reading online postings similar to this one. The majority of my time was spent driving a few times to the Sears Parts Outlet, until I finally got all of the right parts. I could have saved myself a lot of time and effort by doing some simple testing up front. And these tests are real simple, which I will explain below. I wish I knew then what I know now about the repair and troubleshooting steps. It was actually quite easy.
First, the Owner’s Manual is vague about the repair. Under troubleshooting, there is the category of “Not Drying Satisfactorily” with a possible cause that “One fuse is blown or circuit breaker is tripped. The dryer will appear to operate, but you will not get any heat.” The solution says “Replace fuse or reset breaker”. In my case, the circuit breaker was obviously not tripped since the blower motor and controls were still working on the dryer. With that, it felt like the Thermal Fuse 3390719 was the culprit.
Start by unplugging the dryer. Then, the Toe Panel at the front bottom of the dryer comes off easily by inserting a flat head screwdriver along the top edge of the panel, about 4” from the left and the right sides. Pull forward as the screwdriver presses on the retaining clips. The panel is supported by two clips at the bottom, and will then just lift off.
What I found when the toe panel was removed was several years of lint, dust, and animal hair. A surprising amount all over. Having seen this, I suggest that part of Spring cleaning is to remove the toe panel and vacuum the inside of a dryer. Next, to reach the thermal fuse easier, remove the black metal lint duct assembly. Start by removing the lint screen from inside the dryer. Then, remove the two ¼” sheet metal screws on the left and the right of the duct. Now, the only thing holding the lint duct in place is a metal clip at the bottom left, which is pinched in place to the dryer frame. I used a flat head screwdriver to pop it off. The lint duct assembly can now be removed. Here also, I was surprised at how much lint had built up inside the duct. Clean it out thoroughly. Any build up can restrict air flow and waste energy, or be a direct cause to the No Heat problems of the dryer due to poor air flow and heat build up.
With the lint duct out of the way, the thermal fuse is accessible on the top right of the blower housing, as well as the Thermistor 3976615 on its right. What I should have done right here is take the blue wires off of the thermal fuse connectors, and tested it in place for continuity with the fuse still in place. Clean off any dust built up on the inner face of the fuse itself. A basic tester sounded a beep when I touched both connectors, which indicates continuity – or that it is still a good fuse. Install new fuse if needed, and reconnect the wires.
I would do a little more testing first prior to attempting to turn the dryer back on. After all, if the fuse blew, there was a reason. There may still be other things to consider, and you don’t want to risk blowing a brand new fuse.
At this point, I firmly recommend removing the Heater Box and Wire Heater Element assembly. I say this because it actually becomes easier to clean out burnt lint as well as test a few more things. There was enough lint all around and inside this and in the back of the assembly that could have caused overheating due to poor sensor readings.
Start by removing the heat plate at the front. Then, disconnect the six wires from the three devices: heater element, Thermal Cut-Off 3977394 and the Thermostat 3390291. I wrote down the color sequence of the wires to make certain to put them back on the same way. Next, remove the two screws at the bottom of the mounting plate that holds the assembly in place. The heat assembly should now wiggle around some, and be connected at the back of the dryer. There are no screws at the back – all you need to do is rotate the heater assembly counter clockwise about a quarter turn, and it should come out. The entire heater assembly can now be removed from the dryer.
With the Greenlee, I tested for continuity on all three devices: Heater Element, Thermal Cut-Off, and the Thermostat. All three should return an audible beep from the tester, indicating continuity exists. In my case, only the Heater Element was bad and actually had a break in it from overheating. One screw holds the heater element in the housing, so it is easily removed. I had to press on the housing a little to unbind the sides of the heater element, and then it slid right out. The housing can now be cleaned out. Assuming the thermal cut-off and the thermostat tested fine for continuity, all I would do is reach inside the heater housing and clean off the lint and dust build up on these devices, since they appear to be working. Install the new heater element.
While I had everything apart, I cleaned out the flexible duct in the back, vacuumed everywhere inside and out, and even used compressed air to clean out any remaining lint and dust that I could. Reassemble the heater box into the dryer in reverse order. Make sure all of the wires are properly reconnected to all of the devices. Make sure everything is screwed back together properly. Now, reassemble the lint duct by attaching the clip to the dryer and setting the duct in place, and then screwing the two screws back in place. Plug the dryer in and turn it on. If all went well, the heater element should glow orange and there should be heat
Posted on Jul 23, 2010
rickead1
  • 1998 Answers
SOURCE: I have a kenmore elite
its a door switch problem. Make sure the door is latching properly at the top. If the top latch doesn't engage properly the door switch won't make contact.
Try holding the door switch closed with your finger and starting the dryer. If it still wont start and you have no error codes displaying you will most likely have to replace the switch. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Posted on Apr 13, 2011
Testimonial: "dryer is working.... great job. much thanks !!!"
Have a Electrolux dryer and the moisture bar pulled loose by bib overalls and have the new one but am not sure which wire terminal goes where. 2 wires and the dryer used to dry on one normal cycle but
Hello lester haugstad, thank you for your post!
I understand that the moisture bar inside of your Electrolux dryer was pulled loose and you would like to reattach it. I have researched and there is not an available part guide to show how the moisture bar is reattached. I would recommend seeking assistance from a professional for proper installment of the part. I hope this information has been helpful. -Matt
Oct 16, 2014 | Electrolux Dryers
Tip
Dryer operates but will not heat.
1. Disconnect electrical power to dryer.
2. Remove the lid.
3.On the front panel there is a circuit board (moisture sensor control board) with a six pin connector. Disconnect the connector
4. Remove the circuit board from mounting bracket by pushing either the upper or lower lip of the mount bracket.
5.Clean the backside (solder side) of circuit board. I used a toothbrush. 6.Install the circuit board and reconnect wire harness.
on Dec 06, 2008 | Frigidaire GLEQ642A Electric Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
DEGX1 that was not heating correctly. Cleaned behind lint trap and pushed the reset button (did not feel tripped though). My question concerns the "Sensor Conductivity" or two chrome bars at bottom of...
Make sure that onw wire is coneected to the top bar and one wire connected to the bottom bar. DO NOT connect both wires to one bar, it make short out the control circuit. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum make further help you through your problem.
Sep 19, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer does not completely dry the clothes when we use the dryness sensing option. It does fine when we use the timer. Is there a moisture sensor that I might be able to replace ?
Dryers with electronic control and auto dry cycle indeed use moisture sensors for the auto drying to work. The problem is absolutely associated with the failure of the moisture sensors, especially when the timed dry cycle works fine. Either the connection of the sensors to the electronic control is loose or the sensors are covered with thin film that prevents it to sense the proper moisture content of the clothes.
Clean the moisture sensor bars thoroughly and make sure its connections are snug fit. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. The last thing to look into is the electronic control if all resort fail to address the issue, that is, clean sensor bars and good terminal connections.
Indicate the exact model number of the dryer should you need further or more specific troubleshooting and repair advice.
Jun 12, 2010 | Estate TEDX640JQ Electric Dryer
One of the "bars" in the interior of the dryer drum is loose
The front panel needs to be removed before the top cover can be lifted and access the baffle screws for tightening. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to install moisture sensor bar on Maytag Neptune
I do not recognize that part number but an exploded diagram for the dry is at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833
Click on the tumbler diagram.
Mar 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need to replace roller's on LG Tromm Gas front load dryer. The back seems to be stamped to the side panels. How do you take apart the dryer to get at the inner workings?
Unplug power cord. Remove phillips head screws on the bottom side of the "L" bracket on the back side of the dryer's top. Use the flat sides of your hands to sharply push back on the dryer's top, sliding it back about 2 inches and then lifting it off. Remove screw from top corner front corners and pry control locking tabs off from along top edge. (watch for sharp edges) Swing control panel up onto top of dryer. Remove the two screws at the bottom side of the door opening and the four screws along the top of the front panel. Unplug the light, door switch, and also the moisture sensor (by the bottom of the drum) then remove front panel. Remove four screws holding front drum support and lift up on it a bit to remove. Look at how the belt goes around the motor and pulley before removing, then take out drum. You will need to remove the phillips screws from behind dryer to remove the rear drum support assembly, allowing you to get to the nuts on the back rollers. First time job: maybe 2 hours. Second time: maybe a half hour, tops.
Feb 24, 2009 | LG WM-2277HW Front Load Washer
Open Questions:
Dryers Logo
29 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
