Question about Samsung Digimax S630 Digital Camera
Protected pictures how do i delete protected pictures
When i turn my samsung s630 camera on a prepare to take a picture once i push the button to capture the picture it doesnt take the picture, it cycles through the menu options such as the manual picture function, the night vision option, the asr option, etc.
Posted on Oct 22, 2009
  • 76 Answers
You have to unprotect them first... sometimes if you juts format the card (insert into your PC) this will delete protected files as well..
Posted on Sep 27, 2007
  • Adeel Siddiqui
    Adeel Siddiqui Oct 10, 2007
    maybe you should swallow your camera
My camera says internal memory full.How can I delete it?I have tried for a hour and I cannot delete it.The pictures that is.
Go to Menu.
Select a picture or multiple pictures you want to delete.
delete the pictures.
*make sure the file is not "protected" in which case you "un-protected the file and follow through the steps.
Note also that once you delete the pictures, they are un recoverable......you may consider backing up on the laptop or HDD before following through
Mar 21, 2015 | Cameras
Remove picture protection
Select the key icon from the Playback menu to protect/unprotect pictures. See page 33 of this manual: http://www.olympusamerica.com/files/oima_cckb/Stylus_1030_SW_Mju_1030_SW_Instruction_Manual_EN.pdf
Aug 16, 2013 | Olympus ? 1030SW Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Deleting protected pictures
"Protecting Photographs from Deletion
In full-frame, zoom, and thumbnail playback, the button can be used to protect photographs
from accidental deletion. Protected files can not be deleted using the button or
the Delete option in the playback menu, and have DOS "read-only" status when viewed on
a Windows computer. Note that protected files will be deleted when the memory card is
formatted"
This is from the nikon website. You can down load the entire users manual here:
http://www.nikonusa.com/pdf/manuals/dslr/D40X_en.pdf
Dec 24, 2010 | Nikon D40x Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I can't delete protected pictures
That's the point of protecting pictures. You can remove the protection by reversing the procedure. Full details are in the "Protecting images and Sound Files from Deletion (Protect)" section of the manual (page 120 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/files/manual/OptioWPi%20Manual_web.pdf
Sep 13, 2010 | Pentax OptioWPi Digital Camera
Pictures were protected for a temporary photo shoot now I would like to have them unprotected to delete. How does one go about deleting pictures from a Nikon D60?
To unprotect a picture, while viewing the picture press the protect button (marked with a key) to the right of the viewfinder. To delete the picture, press the delete button (marked with a trashcan) below the multiselector.
Jul 07, 2010 | Nikon D60 Digital Camera
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
Deleting protected content
I have a SE K310i. It is the "spiderman3" edition and has a few pictures and a trailer of that movie which are protected( i.e cant be deleted by users like me). delete?
Oct 12, 2007 | Sony Ericsson K310i Cellular Phone
Samsung Digimax S630 Digital Camera Logo
106 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
