Question about Garden
Scotts s1742 mower starter smokes when starting
4 Suggested Answers
emissionwiz
  • 75822 Answers
SOURCE: basic wiring diagram scotts lawn tractor s1742
We don't have any diagrams for this manufacturer, please contact Scott's directly to try and obtain a repair manual which contains the diagrams.
Posted on Oct 25, 2010
ftw1952
  • 10319 Answers
SOURCE: i need a wireing diagram
Your mower is manufacturered by John Deere if you did not know so the schematic will be the same. Thet are sold only through John Deere franchises. None are available on the web as far as I know. I have been looking for years of many models to complete my collection.
Also here is an owners manual in case you need it too
http://www.deere.com/en_US/homeowners/media/pdfs/products_non_current/scotts/lawn_tractors.pdf
Posted on Jul 16, 2011
  • 6468 Answers
SOURCE: i replaced the starter on my scotts lawn mower but wont start
can you turn the engine by hand? if you can use a pair of jumper cables like you would a car and connect from the battery and the block and starter sometimes the cables go bad a draw a lot of amps threw the cables
Posted on May 05, 2012
Can I view the elctrical manual for a Scotts 406777 mower?
Does your owner's manual have a diagram?
Jul 15, 2014 | Garden
How to adjust tension on drive belt for scotts s1742 mower 42 "
Not sure it has an adjustment check for worn parts or belt.
Oct 05, 2013 | John Deere Garden
I replaced the starter on my scotts lawn mower but wont start
May 03, 2012 | Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
The plastic starter gear keeps breaking on my 24 hp. I have inspected the flywheel gear and it is in good condition. I get one or two starts and then the gear breaks. This last time I thought it was going...
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
May 13, 2011 | Briggs & Stratton Starter Scott's Equip...
Ranch king riding mower will try to start but starter wont completely turn moter on then will stop and smoke starter
The starter smoking is an indication that you may have to buy a new starter because when you hold the ignition over to long it will heat up the inside and burn the coil wires inside. But I would try a battery with a higher cranking amp such as a 350 CC. It will turn the engine over faster and easier.
Apr 11, 2011 | Garden
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
