Question about Garden
Honda trx 300ex
Gas goes to the carb and then pours out the overflow line.
    Novelist:
  • 123 Answers
If gas is leaking from the tube on bottom of carburetor, the needle valve is worn inside the float bowl on the carburetor. You should also check to make sure there isn't gas in the oil and in the air box before starting and running your ATV. Let me know if you need any more help, Daniel.
Posted on Oct 21, 2013
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: 300ex weak spark
CHECK THE BOOT THAT GOES OVER THE SPARK PLUG IT MIGHT NOT BE TOUCHING THE WIRE.. ALWAYS TRY A NEW SPARK PLUG
Posted on Sep 15, 2012
Leaking gas out of hose that goes down to battery area when running
The hose that goes down by the battery should be an overflow drain.
Apr 03, 2015 | GAS Motorcycles
Gas pouring out of overflow tube, gas in crank case
Definitely a carb. clean problem. Gas is more than 6 months old & has float needle stuck. Clean carbs. & always replace the float needle valve assy\'s & bowl gaskets. There is nothing you can put in the gas tank to clean carb correctly.
Jan 20, 2014 | Yamaha Motorcycles
Overflowing Carbs again!!!
recheck and clean /adjust floats pet **** doesnt stop fuel in bowl if floats out of adjustment or valve sticking/debris will allow fuel to constant flow
Jun 04, 2017 | Suzuki Motorcycles
Fuel running out of carb overflow pipes
Either the float is set to high, you have trash in the lines, or the more likely scenario is the atmospheric vent line is pinched or plugged.
May 14, 2012 | 1978 Yamaha RD 250
2001 600 grizzly carb flooding
Strip & clean carb then adjust float height
Ride Safe
Bike-Doc
Jan 31, 2012 | Motorcycles
I have a 1995 cbr 600 f3. I stored it last fall and shut the gas off. Now when I start it and turn the gas on, gas pours out of a over flow line and doesn t quit unless I turn off the gas and bike the...
Floats are sticking in carbs and staying open which causes fuel to overflow.you can try tapping float bowls with screwdriver handle sometimes this will free up floats .If this dosen't work you have to remove and clean carbs.Good Luck
Apr 12, 2011 | 1996 Honda CBR 600 F(3)T
When i turn the fuel on to start the bike gas pours out the clear tube that comes from the carb to under the bike some were is this line dis conected or broke or is it something more
it's probably just your overflow from the float. it doesn't connect to anything, it just let the fuel overflow come out when your float level is high. if you turn on the fuel petcock and it starts pouring out, your float needle is sticking. clean the carb and the float needle valve assembly and see what happens.
Dec 30, 2009 | 2003 Yamaha TT-R 125
Gas pouring out bottom of carb won't ping out
Hi and welcome to FixYa,
Gas pouring out is an overflow. The only reason there would be an overflow is when the float activated valve does not close the fuel inlet port. This could be caused by dirt, sand, rust or any foreign material. Fix would call for a carb pulldown, soaking non-rubber parts, and cleaning.
Good luck and thank you for asking FixYa.
Dec 29, 2009 | Yamaha YZ 125 Motorcycles
Gas overflow line coming from carb is pouring out on a 2001 kaw
The float is stuck in the bottom of the carb. Remove the bowl, pull out the float and needle valve, and clean the valve and the hole it sits in.
Jul 08, 2009 | 2001 kawasaki KLX 300
87 yz125. gas pours straight through carb
change the needle and make sure its jetting right, check the floats if it is operational. '90 to '95 carbs are compatible, so if you are planning a replacement, you may use those
Jun 10, 2009 | 2003 Yamaha YZ 125
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
