Question about Home
Hi, I have a Triton Topaz T100si electric shower, the problem with it is that it keeps saying LP (Low Pressure) and it will not heat the water. I have fitted a new Solenoid valve assy. 83307110), but I am still having the same problem, LP (Low Pressure)and no hot water. I have a water pump fitted in my house and it is set at 3 bar. Can you help me. Soli
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
  • 299 Answers
SOURCE: Dial not working correctly, set on low numbers
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Posted on Apr 22, 2010
ZJLimited
  • 17970 Answers
SOURCE: my triton topaz t100si (10.5kw)
If there is no heat at all then you may have a faulty TCO (Thermal Cut Out). A faulty TCO will have no continuity across the two terminals (the black thing on top of the heating tank).
Therefore a good TCO will have power at both connections and a faulty TCO will have power at only one (the function of the TCO is, if the water over heats it cuts the power off to the elements). Here could see one video about some tests...
If there is some heat then It may be a faulty element in the heating tank (there are two, three in most 10kw showers) you can check them with a multi meter you should have a reading of around 12>18 ohms.
If you have power to the elements and no heat it's probably the elements, no power to the elements then it's probably a micro switch.
Hope this helps.
Posted on Apr 28, 2011
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
Apr 16, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
62 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
