Question about Dual XDMAR6720 CD Receiver with Bluetooth, SD, USB, RGB Illumination
Dual Xdmar6720 cd receiver - Dual XDMAR6720 CD Receiver with Bluetooth, SD, USB, RGB Illumination
Hallo my radio is not working after battry changed dual xdmar6720 sound
I would suggest that the battery put in is faulty, if it was new this still may be the case, and you should send it back to the manufactura. Try checking to make sure the battery is in the correct way, and there are no signs of damage to the battery, or loose wires around the battery holder.
Aug 24, 2013 | Dell OptiPlex GX400 PC Desktop
How to enable bluetooth on a XHDR6435 cd receiver by dual
You must purchase the BTM60 module (as it is Bluetooth ready, not Bluetooth capable) like this one at Amazon http://www.amazon.com/Dual-Bluetooth-Hands-Free-Module-Built-In/dp/B000PDR5O6
Sep 23, 2011 | Dual Electronics XHDR6435
CD will not eject from Dual XDM6820 in-dash CD player
you are probably better off just replacing the deck. there is a plastic piece in the dvd mech that breaks and can only be repaired by sending it to dual to be repaired.
Jun 12, 2009 | Dual XDM-6820 CD Player
I need an instruction manual please.
what brand is it, just go to the web site of the brand and you can get the manual there all you have to do is print it out.
May 09, 2009 | Dual Electronics XHD6425 Car CD/ MP3...
How do i fix the error 02 on my dual cd770 cd player
I have a Sony CDX-GT210. How do I set the time? Donna
Mar 31, 2009 | Dual XDMR-7700 CD Player
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Dual XDMAR6720 CD Receiver with Bluetooth, SD, USB, RGB Illumination Logo
48 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
