Question about Whirlpool duet Washing Machines
I have a duet sport WFW8300SW02 which I am having
I have a duet sport WFW8300SW02 which I am having problems with. During a wash cycle it made it to 2 minutes left and then stopped working. I started the cycle again and this time it made it to 9 minutes left. It would not spin out or drain. I unplugged it, drained it manually and opened the door manually to remove the clothes. When I plugged it back in and power up, it will lock the door and then do nothing. If I hit a button, the Add A Garment light will blink. I ran the diagnostics and am getting F26, F20 and F21. I did remove the MCU to take a look at the back of the board as I read in another post here and there is no blackend area or short that I can see. Does this sound like a door latch issue? Should I replace that? Or could it still be the MCU?
  • Matt
    Matt Oct 22, 2013
    The door locks and then that's it. Nothing else happens. I'm going to start by replacing the door switch assembly and then go from there...
    Sergeant:
    Champion:
  • 257 Answers
Here is the code meaning
F26 is for door lock - do you hear the door lock one time or with click sound repeatedly.
F20 no water entering - do you check water coming into washer
F21 long drain-do you take a look of pump filter
Another possibility is the pressure switch was bad.
Hope you can figure out the issue.
Posted on Oct 22, 2013
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
SOURCE: Kenmore washer stopped with F21 error code
This solution is the best! Thank you so much. You just saved us a whole bunch of $$$ and frustration. 1 baby sock and 1 pair of undies later - the machine is back to normal. THANK YOU!
unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. In my case, there was a piece of a pencil lodge in the pump impeller. I had to disassemble the pump. it can be done if you are patient and able to figure out how the plastic thing come apart. Good luck! If all else call the pros!
Posted on May 01, 2009
SOURCE: Problem with F21 code on whirlpool duet sport
i had the same problem. take the bottom cover off of the front of the washer. on the right you will see a round white screw off cover, it is very tight, it unscrews counter clock-wise. pull this out and see if there is any debris in it. if you look into the hole on the right side there is a hole about 1 inch round, this is the pump opening. you may have to take the gray drain hose off of the back of the pump housing and feel if anything is stuck in there, in my case there was a penny stuck side ways blocking the flow of water. after i took it out the washer has been running great again. this is obviously a design flaw, that something that large could manage to get that far, lucky for me it didn't damage the pump impeller. hope this helps. this should take care of the SD and the F21 error codes.
Posted on Aug 23, 2009
jsrock516
  • 5911 Answers
SOURCE: wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Sep 11, 2009
Whirlpool washer duet sport ht MOD # WFW8300SW02
did you try to diconnect it from wall?
try to disconnect it.... wait for 5 minutes and try to connect it again and try if same problem still occurs....
Jan 13, 2014 | Washing Machines
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Washer (model: wfw8300sw02) partially drains. Clothes spin out as dry as ever, but 2-4 cups of water are always left in the filter/pump. I've 1) emptied the filter 2) disconnected...
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Jun 07, 2011 | Whirlpool Washing Machines
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F1 code for duet sport
you have a bad machine controller, check the warranty in your use and care guide to see if the part is covered under manufacturer warranty.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer powering off during spin cycle
I had this problem with new duet sport washing machine. Service was out to fix under warranty (4 trips!) replacing water sensor and boards. Finally checked outlet and was told no neutral. ?? Charged us for that visit since not covered. Plugged into another outlet and it worked. Had electrician in, replaced original outlet (although saw no sign of bad connection) and washer worked again! Yippee until today when I had the same issues. Tried in another 2 outlets and still shut down after a few minutes (and in those few minutes it never really ran as it should) Went out to get an outlet sensor ($8 at hardware store). Plugged in and found no errors. Started washer again and it did run and completed cycle. Although estimate 1 minute of final spin cycle took almost 25 minutes (on QUICK wash no less!) Will have to monitor. See if we get lights on outlet sensor next time washer doesn'twork, see what other things in house are running, etc. (although washer on dedicated line). ONLY change since this happenned: We replaced our 30 y.o. electrical box. You'd think this would be better???
Nov 30, 2008 | Washing Machines
Washing Machines Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
