I just bought a 1970 soundesign turntable 4236f. the speakers work but will fade in and out sometimes. what would cause that?
  • Audio Player... Master
  • 5,158 Answers
Unless it's second hand you should take it back to where you got it from. If it is second hand, then it will be hard to track it down. My guess would be either a faulty IC in the pre-amp stage. But it could just be a dry joint on the solder, since it's been moved.
Posted on Oct 25, 2013
2 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: My SounDesign Player Turntable System
Try to lift the table (it might have a "c" clip lock in the center) and check the belt or idler tire on the bottom of the table.
Posted on Feb 07, 2011
JVC - Turntable - QL-F4 - Noise coming from the motor ?
You don't say whether your turtable is grounded by a separate wire but in some cases grounding is necessary to eliminate hum.
Feb 25, 2014 | JVC Audio Players & Recorders
Blown speaker
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
Jul 10, 2013 | Jensen JTA460 Turntable
My SounDesign Player Turntable System will power up but the platter won't spin.
Feb 07, 2011 | Audio Technica AT-LP2D Turntable
Erratic volume from new turntable thru used amp
First detirmine if it is only the turntable that is causing this problem, by connecting something else to another terminal. If that works fine it will be the cartridge preamp that is causing the problem. From what you describe it sounds like an IC that is playing up.
If the other device plays up as well as the turntable, I still suspect an IC, but this time in the main pre-amp. The reason I suspect an IC is that by the sound of things both channels are playing up and therefore it has to be somepart that has both channels going in and out of it- thus IC!
May 08, 2010 | Audio Players & Recorders
I'm having problems with my Soundesign turn table... After finishing a record it auto-returned the stylus, and since then the turntable won't turn. I can't remove the platter, however I can lift it up...
I actually had the same problem with my soundesign. Really sucks that we can't remove the platter. However... I just jiggled mine for a while and it started working again. I know that doesn't sound like a real solution, but I would just try playing with it for a while. Mine worked after that..
Do you by chance have any idea how to get closer to the belt? Mine is having a speed problem and needs adjusting but obviously the platter is a ***** to take off.
Jun 29, 2009 | Audio Players & Recorders
There's only sound in the left speaker.
when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 24, 2009 | Stanton STR8-30 Turntable
Buzz coming from speakers on phono input
is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
Jun 21, 2009 | Technics SL-BD20D Turntable
My turntable has a crackling sound that makes the sound fade i & out . what could be the problem?
I assume you mean the output makes the crackling sound, not the turntable itself.
Is it only the turntable doing this? No other source? If yes, turn off your receiver and manually operate every function and control throughout its range and toggle every switch and button repeatedly to remove oxidation. The Tape Monitor control is famous for causing droputs even when it is OFF.
Listen carefully to the sound.
Is the sound dropping out or is the volume fluctuating?
Is the turntable tracking proerly or is it skipping, lifting off the platter?
Is it on both channels, one or random?
DE-select the phono on the receiver so the following is not passed through to the speakers.
Remove and reinstall the RCA phono plugs from your receiver using a twisting motion to remove oxidation. How is it now?
Mar 09, 2009 | Technics SL-1210 Turntable
 Grubhead
Grubhead
