Question about Carrier Heating & Cooling
CARRIER AIR HANDLER CODE 41 BLOER MOTOR SPEED FAN TRYS TO BUT VERY SLOW FOR ABOU 10 SEC SHUTS OFF AND RECYCLES AGAIN THE GOES TO SHUT DOWN WITH CODE 41
  • 148 Answers
Check capacitor
Posted on Nov 10, 2013
4 Suggested Answers
  • 7 Answers
SOURCE: EverStar MPM2-10CR-BB6. Comp. only runs for about
check the start gear for the comp.
Posted on Jun 27, 2009
meBNme
  • 334 Answers
SOURCE: Goodman Air Handler motor will not turn off.
Look at your Thermostat wiring.
If there is a green wire going to the "G" terminal, disconnect it.
If it stops running, you have a bad T-stat.
If it keeps running, you either have a stuck fan relay or a low voltage control wiring malfunction.
Those are usually related to one of the safety switches having problems.
If green is not going to G, let me know, and we will determine which one is indeed the fan wire and go from there.
Remember, when you rate the solution, it closes further dialog, so only rate when you are satisfied with the discusion.
Thanks for visiting FIXYA!
Posted on Jan 03, 2009
  • 37 Answers
SOURCE: Trane air handler model #TWV036B140A Fan wont stop
Sounds like you have a bad fan relay, the fan should shut of within 30 to 120 seconds after t-stat is satsified.
Posted on Apr 25, 2009
My air handler keeps trying to blow but keeps stopping the outside unit is working fine, it is an Amana unit.
The most likely things, in order, are:
1) There is too much dirt, dust or lint clogging the squirrel cage fan, slowing it down and causing the motor to overheat and shut off.
2) The motor is clogged with dust or dirt and is overheating and shutting off.
or 3) the ductwork is clogged, causing the motor to overheat and shut off.
God bless your efforts.
May 11, 2018 | Amana Heating & Cooling
Is there a reset switch on Carrier airconditioner
No turn you termalsate to the off pos. Then to fan on. Them see if it goes off and then switch to cooling on the coldest sting if the fan in air handler shuts off before. The stat tells it to it might be kicking out on thermal overload bad motor. Check the condnsor fan for this to fans don't turn on unless they are told to by power going to a board or a relay low voltage control wires may be damaged clean the units pay a tension
Jul 31, 2016 | Carrier Heating & Cooling
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Fan quits and the compressor still runs
is this a split residential system. it sounds like you are talking about the condenser fan either way it seems like the fan is overamping and tripping on thermal overload which is a device in the motor that protects itself. when you shut it off for a while and turn it back on does the fan work. if you turn it off then turn it right back on does the fan work. when it shuts off is the motor really hot. if possible, and you know how, check amp draw. typically you can find the rated amp draw on the motor nameplate.
May 27, 2009 | Carrier 52CQ315 Air Conditioner
Carrier A/C Intermittent Shut-down Problem
It sounds like there is something in the system that is over heating. A t-stat will either work or it won't there are relays that have 24v coils and can become weak. If your air handler is shutting down it shut down the condenser, if the air handler is staying on but condenser is shuting down check the outside contactor. I am an a/c contractor and can be contacted at 504-722-3946 Eddie.
Sep 29, 2008 | Carrier 38BRC048 Air Conditioner
Furnace come on then fan stops while burner still is on, then fan comes on for 1 min. and goes off over and over
This could be a couple of things, first is the fan limit switch. Make sure your fan limit is set at the correct settings, there is a fan on setting and a flame shut off setting located on the front of air handler inside the front cover. Usaully set at 140 fan on 200 gas shut off. You do not say what unit you have so this could be a pc board or module. Second this could be the blower it's self over heating and shutting down, feel if motor is gettig hot. This could be a run cap. or motor it's self. But it is more than likely the limit switch.
Sep 29, 2008 | Coleman Heating & Cooling
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
184 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
