SOURCE: canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
SOURCE: Canon IXUS 970 IS Digital Camera Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater
for you causing greater damage. BUT would instead recommend that you
try the seven sequential repair step outlined for a lens error in the
below listed Related Link "Fixing a Lens Error on a Digital Camera".
None of the steps outlined in this link involve opening the camera. and
reportedly you should have close to a 50% chance of success with these
techniques.
If you cannot repair the lens yourself with the
first related link, then consider trying the two 'Digital camera
repair" links below for two online digital camera repair businesses.
SOURCE: Need instruction manual for a Canon IXUS 9515 digital camera
In the Americas, this model is the PowerShot SD1200 IS. You can view and download the Camera User Guide for it here.
